JanRV6UK
Happy new year to you all !
I am slowly making progress on my RV6 slow build ? With the fuselage still upside down in jig I am now ready to dimple / countersink all the holes to get the skins ready for priming - I have a few questions regarding the best way to prepare the holes in the longeron ? I find the drawing not to be very clear ....
From Bulkhead F605 all the way back I have drilled for 426-3 with a 1? spacing.
Is the general view that it is best to countersink the longeron all the way ? then dimple all the skins ? ? Then back drill when the fuselage is out of the jig to secure the two rear top skins ? and dimple them as well.
From Bulkhead F605 to the firewall ? I plan to drill for 426-4 with a 1 ? ? spacing ? Clearly the longeron has to be countersunk here to take account of the larger rivets.
On the part of the fuselage that is behind the wing root ? I plan to use mostly 470-4 rivets ? But on the F604 bulkhead at what point do you transition to the smaller 426-3 rivets ? Or do you use 426-4 up to the longeron, or just up to the part that is viable outside the wing root ? Then 426-3 all the way up to the longeron ?
On F605 at the top end I have the F605 E channel with the two spacer strips H & I (I am building a tip up canopy) ? With the spacers strips in place I can not see how I can dimple that part of F605 ? So countersinking looks appropriate ? then I can dimple the skin ? the part of F605 that does not have the E channel can of course easily be dimpled.
Does this all make sense ??
Jan
2012 ? paid up...
2013 ? Not yet ? on the to do list ...
Jan
2012 ? paid up...
