Old 09-26-2018, 10:39 AM
dwranda dwranda is offline
Default oil pressure fitting before hanging engine?
I've read on other posts that before hanging the engine you should definitely install the fitting for oil pressure because it's very hard to install it after hanging. Is this the fitting? Mine is a Mattituck IO360.
https://www.aircraftspruce.com/catal...clickkey=50474
9A in progress
Working on Finish kit!!
Mattituck TMXIO-360 red gold
Dues paid Dec 18
Old 09-26-2018, 10:48 AM
pilot2512 pilot2512 is offline
Yes. They are $24 at Vans
Jay
RV-9A
Empennage complete.
Wings complete.
Fuselage in progress
Wiring in progress
2018 Donation made!
Old 09-26-2018, 11:11 AM
Excellent thanks!! Is there anything else I should look at installing? When my cowl shows up I want to hang the engine to start fitting it.
9A in progress
Dues paid Dec 18
Old 09-26-2018, 11:19 AM
You may want to order 3 of them. Oil pressure, fuel pressure and manifold pressure. Also there is a special t fitting for the fuel pump
Jay
RV-9A
Empennage complete.
Wings complete.
Wiring in progress
2018 Donation made!
Old 09-26-2018, 08:27 PM
johnbright's Avatar
johnbright johnbright is offline
Default VAF article
http://www.vansairforce.net/articles...inehanging.htm
John Bright, RV-6A 25088, at FWF
O-360, 8.5:1, vert sump, SDSEFI EM-5
Z-14 adapted for EFI, wiring and IP CAD files here
Newport News, Va
Old 09-27-2018, 11:23 AM
jrs14855 jrs14855 is offline
Default Oil Pressure Fitting
Note that some late manufacture engines have a port on the aft side of the accessory case.
Another option is to use the forward end of the oil gallery which is much easier to access. This will result in oil pressure readings approximately 10 psi less than at accessory case. New Cessna's use the forward end of the gallery for oil pressure connection.
