I am getting a very significant nose wheel shimmy at between 30 kts and about 60 kts.
I have tried adjusting the caster tension from light to rather heavy with no help. Any ideas?
The Lancair 235 with the old-style nose gear used a 3"-4" nylon disc between the fixed and moving portion with tension set by Belleville washers. However, my friend had his nose-wheel shimmy and then collapse because some oil got on the disc!
First comment will be: 60 kts!, holy cow, what is the nose wheel doing on the ground at 60 kts .
Yep, there's not a problem if your nosewheel experiences shimmy at 60kts. Nose wheel should be off the ground above 25kts on both take-off and landing. With my Hartzell prop, I get to 25 so fast I have no idea what the actual number is. Just hold the nosewheel off the ground and let the airplane fly itself off. That's it. Very simple.
Believe me, I don't intend to sound judgmental at all. I would hate to discourage anyone from posting questions on this forum. Any question is a good question in my mind. Having said that, I do believe that excessive speeds of the nosewheel on grass is one of the causes of many of these noseover accidents that we are seeing.
I would also say you should increase the tension on the castering nut. I beleive the manual calls for 25 pounds of breakout force and 30 pounds of air in the tire. I have an airport neighbor that runs more like 50 pounds of breakout force and 45 pounds of air in his front tire. He has very little to no shimmy.
This is in an -8A, so your experiences may vary.
The best idea I've seen to mitigate the A model shimmy is a wood stiffener..........
The angle of the gear leg doesn't really count. The pivot axis of the spindle (our "fork") governs. With Van's design, "caster length" and "spindle offset" end up being about the same and high, at about 7.5 inches.
Just made my first flight in my 8A "LOVED it"! But i now have a nose wheel shimmy that just is getting worse. I didn't have it on my high speed taxi or during a couple of crow hops. After my first landing it started and contiuned even during taxi. i torqued the nut to the proper 20lb force as stated in my manual. Any suggestions????
