Old 09-08-2018, 08:05 PM
rvator4twa rvator4twa is offline
Default Antenna location for UAT Exho on RV-6A
Am installing the UAT ABS-D unit to go with my GRT Sport EFIS. I have located the transponder type antenna just forward of the R step. I located it there as it provided easy access to drill thru the bottom of the plane with inside access only removing the,side cargo wall door. It also is more than a meter behind the actual GTX327 transponder antenna. A friend wondered if the step would dissipate part of the signal? Will contact someone Monday but any opinions?
Ron Burnett N524RB
RV-6A Lycoming O360 dual EFII
M71-Greensfield, MO near St. Louis
Dues gladly paid Nov. 2018
Old 09-08-2018, 09:25 PM
erich weaver's Avatar
erich weaver erich weaver is offline
Everything dissipates the signal. The further from the step the better, but whether it is significant or not where you have it is tough to judge until you try it. Unless you are quite close, Iím guessing you will be ok
Erich
Old 09-08-2018, 09:41 PM
Default Antenna distance
It is only about 4 or 5 inches in front of the step. ??
Ron Burnett N524RB
Old 09-09-2018, 08:49 AM
painless painless is offline
Slould work. My Adsb antenna is just behind the firewall, which puts it close to the exhaust stacks. No issues.
Jeff Orear
RV6A N782P
Peshtigo, WI
Old 09-14-2018, 02:24 PM
Default UAT ECHO antenna location
It works great.
Thanks for help.
Ron Burnett N524RB
