Old 07-03-2018, 04:37 PM
Larry DeCamp's Avatar
Larry DeCamp Larry DeCamp is offline
Default 0360 / 180HP oil cooler Question ?
Vans supplied me with a Niagra 2002A 7 row cooler with my 0360 baffle kit.
I have read the archives regarding screens, vernatherm seating, sensor location, more rows, double pass etc. Assuming the baffles are leak free , why should I expect problems with a single pass / 7 row as supplied by Vans ? It is still in the box so I can change course if justified.
Larry DeCamp
RV-3B flying w/ carb / Pmags / Catto 2b / Steam
RV-4 fastback w/ Superior XP360/AFP/G3X/CPI/Catto3b
Clinton, IN
Old 07-03-2018, 04:48 PM
erich weaver's Avatar
erich weaver erich weaver is offline
Simple. Many, although not all, have found that oil cooler marginal or worse with respect to its ability to keep the oil within the desired temperature range. It was not sufficient for my IO-360B1B built by Aerosport Power from ECI parts.
erich
Old 07-03-2018, 05:03 PM
Default Thanks Eric
So what should I replace it with ?
Larry DeCamp
Clinton, IN
Old 07-03-2018, 07:21 PM
Jpm757 Jpm757 is offline
Larry,
Mine is installed per plans behind #4 cyl. (IO-360 M1B). Ran too cool in winter ops., I couldn't get temps above 150F. I installed Anti-Splat shutter, and was able to get temp up to 180F at 10F OAT. Summer ops. with shutter full open and OAT 90F I'm seeing 190-200. I am using silicone baffle seals which I think greatly improves cooling efficiency. Make sure your oil temp gauge accurate.
Jake
RV6 #20477 completed 1991 sold.
RV7 #72018 N767T first flight 11/21/2017 200+ hrs.
IO-360M1B MT 3 blade, Dual AFS 5600 QUICK Panel.
KOXC Oxford, CT
1941 J3 Cub skis,floats.
2019 dues gladly paid.
Old 07-04-2018, 07:25 AM
Talk to the oil cooler suppliers to get their recommendation on a cooler. I like Bill at Airflow Systems because he can help with installation options and hardware while Pacific Oil Coolers does not. Depending on which cooler you go with and the configuration of the engine mount, you may or may not be able to mount the cooler on the baffles. I went with AFS 2006X cooler on my -7A and am satisfied.
Erich
Old 07-04-2018, 08:14 AM
Schooner69 Schooner69 is offline
Larry:
Here in the Okanagan, the winter temps average between freezing and 10 F. I, and many others, use a home-made, cockpit controlled, oil shutter to control the oil temperature. If required, we also restrict the air intake to the engine if warranted.
Old 07-04-2018, 08:33 AM
Zuldarin's Avatar
Zuldarin Zuldarin is online now
Larry, it depends on your engine. Cold air induction, piston oil squirters (angle valve usually) and electronic ignition all affect either the amount of heat added to the oil, or the ability to remove heat from the oil. I have all three and only now feel I have my oil temperature under control after installing a 15 row cooler on my firewall.
My opinion (worth what you paid for it) is to go oversize if you have any of those configurations. You can always block air flow to the cooler if its too cool. Its a much bigger and expensive project to increase the cooling capacity of your system.
If you want to read a little more on my project to install a larger oil cooler you can find more info starting here.
Darin
Snoqualmie WA
RV-9A Flying as of 03/2015
RV-10 Building - Fuselage
www.DarinAnderson.com
2019 donation sent!
