The procedure Carl Froehlich described is what I did, only I extended the 2 bid maybe 1/2" onto the plexiglass.
I believe that is what Carl did. He didn?t let it extend past the inside joggle.
Which Weld-on are you planning to use? #40, or other? I am about to do a windshield on my build (not RV) and have decided on Sika-flex 295UV due to the fact that Weld-on looks like it could be a real PITA. Saw a lot of comments on how hard the process and mixing is. Comments?
I used Weld-on 10 from Van's,Aerosport was out of the Lord adhesive that I would have much preferred but they didn't know when it would be back in stock.
I can confirm Weld-on is a pain to work with. Stringy and at least in Tx summer temps,a very short working time. But got it done. Didn't find mixing it to be difficult though.
I bet Muskateer windows have never been subjected to the lift generated at 200 mph! ��
