grayforge
Hi folks,
I'll be sending an email to Vans as well, but thought I'd check opinions here too.
I have a tiny bit of play in the inboard aileron hinge/bearing. I imagine it's the bearing shifting slightly in the sandwiched aluminum sheets that form the hinge. The movement isn't a lot, but you can just see and hear it (so maybe 1/64 or so). Photo below.
One thought I had was to drill out the 2 rivets holding the top of the hinge plates together, pry apart slightly and drip some Loc-Tite onto the bearing to fill the space (trying not to get it in the bearing).
Thoughts on if this is anything to worry about and if so, fixes?
I wish I had noticed this when I first built the hinge. Now the fix (if needed) will be a lot more involved.
Thanks!
Russ
The offending hinge:
Thanks!
Russ
