Geico266
Read about the EAA/AOPA proposal here.
http://www.eaa.org/news/2012/2012-03-20_exemption.asp
"Currently, FAA regulations require all pilots to hold at least a third-class medical certificate to exercise the privileges of a private or recreational certificate. EAA and AOPA are asking the FAA for an exemption to that rule, which would give pilots who fly recreationally the option of getting a third-class medical or, instead, participating in a recurrent online education program that will teach them how to self-asses their fitness to fly.
The education program will cover aeromedical factors and exceed the training presently mandated by the FAA. Participating pilots would also be required to hold a valid driver's license and conduct a meaningful self-assessment prior to flight. The self-assessment required in the exemption will be similar to what pilots do now between AME visits. The difference is that pilots will have a higher level of knowledge to do the self-assessment after completion of the required education program.
The requested exemption would help to mitigate the increased risk inherent in transitioning to unfamiliar and sometimes distinctly different aircraft, which is the only current available alternative to the FAA's third class medical.
This exemption request has been built upon substantial evidence obtained over the past 20 years, most recently proven through the successful medical safety standards allowed under the sport pilot certificate, which currently utilizes the driver's license medical standard in lieu of an FAA medical certificate"
Then take a moment and send your comments to the FAA via one of the following methods. Use some of the words from the paragraphs above.
I received the following from Randy Hansen at EAA Hq today on the best ways to voice your comment.
"The EAA does not have a ?sign a petition? web site like the AOPA. The primary reason is that the FAA views a petition with signatures as a single (e.g., one) comment, even if the petition has 30,000 signatures on it. So EAA elected not to follow the petition route that AOPA is using."
Here are the four other options for submitting your comments.
1. By US mail:
U.S. Department of Transportation Docket Management System Attn: Comments to FAA-2012-0350 400 7th Street, S.W., Room PL 401 Washington, D.C. 20590-0001
2. By the worldwide web:
www.regulations.gov, then enter "FAA-2012-0350-0001" in the search block, then follow the "submit a comment" icon on the right side of the page.
3. By fax - 202-493-2251 Reference: FAA-2012-0350-0001 Comments
The DOT Docket system does not accept comments by e-mail.
4. The fourth option is to send your comments directly to EAA by e-mail and specifically state that you wish EAA to submit your comments on your behalf. If you prefer this option send your comments to Catherine Lute, EAA Member Services, [email protected]
SEND your comment today to support this proposal!!
IF YOU ARE A MEMBER OF ANOTHER CHAPTER, PLEASE FORWARD THIS ITEM TO YOUR MEMBERSHIP!
1. By US mail:
