Old 02-10-2020, 05:01 PM
bill@fusion4.net's Avatar
bill@fusion4.net bill@fusion4.net is offline
Question Replace a Right Mag with Left?
Pulled my left mag when got the engine (YIO-540-D4A5) and put lightspeed in itís place. Hit the 500hr mark and need to do maintenance on right mag. Are they the sam, can the left be installed on the right side? Looking at aircraft spruce, they donít specify a right vs left. Both slick mag 6350.
Guessing it is ok to do, but saw for at least some engines that is not the case.
Bill Thomasson
RV-10 - Flying - Phase II. 99.8% done... it's never really done!
http://sites.google.com/a/fusion4.net/rv10/
Suwanee, GA.
Old 02-10-2020, 06:46 PM
plehrke's Avatar
plehrke plehrke is offline
RH mag not same as left mag has the LH mag has the impulse coupling to retard the timing during start. Putting a impulse coupling mag on RH side with EI on LH should be ok and aid in starting but I donít know anything about Lightsoeed EI. I have kind of opposite with SDS CPi on RH with impulse couple mag still on left.
Philip
RV-6A - 13 years over 900 hours
Based at 1H0 (Creve Coeur)
Paid dues yearly since 2007
Old 02-10-2020, 07:13 PM
D Weisgerber's Avatar
D Weisgerber D Weisgerber is offline
Thats not correct for all engines, some engines run impulse couplers on both mags, I suspect that is the case in the OP engine.
RV6 N7219d
IO-320-B1A
Sam James cowl
first flight May 2, 1997
RV8 #83830 tail done
Wing and fuselage kits ordered
Old 02-10-2020, 07:26 PM
Walt's Avatar
Walt Walt is offline
The 540 is "normally" delivered with retard breaker mag/slick start 6393 on LH side and std mag 6350 on RH side. So if that's the case you could indeed use the LH mag in the RH side and just not use the retard breaker connection.
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
