Go Back   VAF Forums > Main > RV Building Tips/Techniques
Old 02-06-2020, 12:18 PM
wolfcj1 wolfcj1 is offline
Default Best way to cut/trim fiberglass fairings?
Replacing cracked main wheel fairings on RV-12 with fairings from Vans. KAI says to trim fairings to scribe line to widen wheel opening with "sheers". The material to is too thick for me to cut with hand sheers. Would appreciate recommendations on how to best cut through/trim this material.
Old 02-06-2020, 12:35 PM
fl-mike's Avatar
fl-mike fl-mike is offline
Dremel or die grinder with abrasive cutoff wheel.
Mike W
Venice, FL
RV-6A. Mattituck TMX O-360, FP, GRT Sport EFIS, L3 Lynx NGT-9000
N164WM
N184WM reserved (RV-8)....finishing kit in progress. Titan IOX-370
Old 02-06-2020, 12:45 PM
scsmith scsmith is offline
In addition to abrasive cut-off wheels, Dremel also makes small diamond wheels. We find those work best for trimming composite in our shop. With either type, go slow so you don't burn the resin. Start with a shallow cut, then finish with a full depth cut.
Steve Smith
Aeronautical Engineer
RV-8 N825RV
IO-360 A1A
WW 200RV
"The Magic Carpet"
Hobbs 600
also LS-6-15/18 sailplane
VAF donation Jan 2020
Old 02-06-2020, 12:49 PM
RV10Pilot RV10Pilot is offline
Dremel works. Perma Grit disc is the best, but for your one off use any of the dremel discs.
Or my prefered method is using a vibrating multi tool, cuts like butter and I find easier to control than the rotating disc.
Old 02-06-2020, 01:59 PM
Bob Martin's Avatar
Bob Martin Bob Martin is offline
Sounds like a great idea.....have to steal this idea!! SMILE
Bob Martin
RV-6, 0-360 Hartzell C/S, Tip up, 1200+TT
James extended cowl/plenum, induction, -8VS and Rudder. TSFlightline hoses. Oregon Aero leather seats.
D100-KMD150-660-TT ADI2- AS air/oil seperator. Vetterman exhaust with turndown tips.
Louisa, Virginia KLKU N94TB
Old 02-06-2020, 02:59 PM
12vaitor 12vaitor is offline
+1 on the oscillating multi-tool, its the first tool I reach for when trimming composite materials. The circular blade seem to work best for me from a cut control standpoint.
John Salak
RV12 N896HS
Old 02-06-2020, 03:46 PM
snopercod's Avatar
Back in the "olden days" when I built my Lancair kit. I used "rotary scissors" to trim the parts. That worked great, but I don't think you can buy them any more. These days I use a Structered Carbide Dremel tool like this one: https://www.dremel.com/en_US/product...e-cutter-taper
(2020 dues paid)
Old 02-06-2020, 04:10 PM
DanNiendorff DanNiendorff is offline
John Salak
RV12 N896HS
Also, the oscillating tool makes WAY WAY less dust and mess. #1 tool for cutting fiberglass in my book.
RV-14A 140658 Empennage in progress
Zenith CH801 - old school pre-CNC era kit - flying
Zenair 2500A amphib floats - From basic parts kit - 80%
Dues 2020 ✅
Old 02-06-2020, 04:39 PM
wjb's Avatar
wjb wjb is offline
No a fan of the permanent-grit disks; they seem to be unbalanced when I spin them. Dremel has a series of fast change reinforced disk that work well. The smaller, all ceramic disks work but are quite fragile.
Bill Bencze
N430WB RV-7 #74152, tip-up; IO-360; CS. Pushing toward first flight in 2020!
Log at: http://rv7.wbencze.com
Defeating gravity one rivet at a time
VAF 2020 donation happily made
Old 02-06-2020, 04:51 PM
N941WR's Avatar
N941WR N941WR is offline
Use black electrical tape to mark your cut line. It stretches and conforms to odd shapes but gives a good line to follow.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
