Go Back   VAF Forums > Main > RV Ongoing Maintenance Issues
Old 01-27-2020, 09:56 AM
Pilot135pd's Avatar
Pilot135pd Pilot135pd is offline
Default After an Unairworthy Condition Inspection
Was hangar flying with a friend the other day and the topic of the Annual Inspections and Condition Inspections came up.
On a Standard Airworthiness airplane the Inspection is done and there are 2 options that usually happen:
1- the discrepancies (or squawks) get fixed and the Annual Inspection is signed as Airworthy and returned to service.
2- the discrepancies get written up (squawk list) and the logbook is signed as Unairworthy with discrepancies given to owner. Then at least an A&P will correct the discrepancies and sign the logbooks with their certificate as done. That brings the plane back to Airworthy.
Then we started talking about Experimental airplanes:
All maintenance on my Experimental plane can be done by me. I'm not an A&P and don't have a Repairman certificate of any kind.
In Experimental airplanes the Condition Inspection must be done by at least an A&P.
Here's were we got stuck. Say an A&P does my Condition Inspection and finds some deficiencies. Can he sign the logbook as Unairworthy and give me a squawk list like a Standard airplane or does he have to repair anything and sign it as Airworthy?
If he can sign it as Unairworthy and give me a squawk list, can I fix the squawks and return it to service or does it have to be another A&P?
Please include FARs with your replies so I can research it further and learn from you. Thanks !
(*** In MY specific case it would most likely get fixed by another A&P because depending on what it is I probably don't have the expertise, but I'm asking in general terms. ***)
RV-8 N52VM: Dynon D-180, Autopilot, Titan 0-360A1A, Hartzell C/S, INS-429 IFR, WingX & Stratux for backup & ADS-B IN. Enjoying life while building a FREE campsite for pilots www.facebook.com/VacaMooAirport/
Exempt by 3 out of the 10 ways but I still donated.
Old 01-27-2020, 10:07 AM
bkervaski's Avatar
Not true .. If you hold a Repairmen Certificate for your airplane you can sign off your own condition inspection ..
I may be wrong, have never owned a certified aircraft, but I don't think an A&P can sign it off as "unairworthy" they simply don't sign it off at all until they find it airworthy (all the issues resolved).
But curious to me as well, since you don't have a repairmen certificate, what constitutes "maintenance"? I don't think, for example, replacing a control surface is maintenance. However, per Part 43, oil changes are.
So if you're not a Repairman are you limited to Part 43 like a certified aircraft?
RV-14A #140376
N196 (Flying)
2019 Bronze Lindy
Old 01-27-2020, 10:14 AM
Pilot135pd's Avatar
I said an A&P is needed for the Condition Inspection because the Repairman can only do his own so someone with a Repairman certificate would not encounter the situations asked about in this topic.
Old 01-27-2020, 10:19 AM
bkilby's Avatar
bkilby bkilby is offline
Anyone can do anything on an experimental. Reskin it, rebuild the engine, change the tires, whatever... When it comes condition inspection time, gotta be the builder or have repairmen cert or any A&P can sign off on it.
Brian Kilby
flying RV-6A, previously flying RV-9A
based at KCTJ, Carrollton, GA
Old 01-27-2020, 10:25 AM
Sam Buchanan's Avatar
been here awhile
No.
xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
Sam Buchanan
1999 RV-6
1918 Fokker D.VII replica
Old 01-27-2020, 10:48 AM
Default What I do
So, for topic of this thread, I am an AP/IA, and I do inspections on both certified, and experimental, many of which are RV's that were not built by the owners. I typically do the inspections with the owner present, because I learn what he or she has done, and they learn from my building/inspecting/legal aspect. If I find an issue needing immediate attention, I offer them the opportunity to correct it themselves, or have me do so. I make a list after the full inspection, and if they flew to my facility we correct before they leave. If I am inspecting at their own hangar, I will request the item be corrected (by them or myself), and I will then look at just those items to achieve the condition inspection. I never make a logbook entry of an aircraft being non-airworthy, or not in condition safe for flight...just bad taste to smear a logbook with that kind of stuff.
Bill E.
RV-4/N76WE
8A7 / Advance NC
Old 01-27-2020, 10:56 AM
DanBaier's Avatar
DanBaier DanBaier is offline
Hopefully Mel or Vic will weigh in.
I don't think the experimental aircraft is found to be "airworthy" (that it conforms to it's type certificate and approved data, and is in a condition for safe operation - definition per FAR). Instead, for an experimental, the logbook entry is specified word for word in the letter of authorization that came with the experimental airworthiness certificate - simply that the aircraft was inspected and found to be in a condition for safe operation.
It would seem to me that someone with the appropriate repairman's certificate or an A&P could inspect the aircraft. If it's in condition for safe operation, it gets a logbook entry. If not, there is just no entry made of any kind.
Dan
RV7A (N7101) - Flying 10/2008
CFI- SE/ME/Inst
A&P
KC2ZEL
Old 01-27-2020, 11:03 AM
rocketbob's Avatar
rocketbob rocketbob is offline
I don't know an IA (myself included) that would get paid to sign something off as unairworthy. If I find something, as I often do, it gets fixed before the annual is signed off. Same goes for condition inspections.
Please don't PM me! Email only!
Bob Japundza CFI A&PIA
N673AC RV-7 borrowed horse
N678X F1 Rocket, under const.
N244BJ RV-6 "victim of SNF tornado" 1200+ hrs, rebuilding
N8155F C150 flying
N7925P PA-24-250 Comanche, restoring
Not a thing I own is stock.
Old 01-27-2020, 11:35 AM
jliltd jliltd is offline
I completely agree with the sentiment that no IA and/or A&P should ever make an unairworthy emtry in a log book. That makes no sense unless someone is being vindictive at the worse or plain ignorant at the least.
If an aircraft owner doesn't want necessary airworthiness items addressed they can just pay for the work to date and take their airplane and log books back without an annual inspection or condition inspection entry.
Jim
RV-8
RV-3B
Old 01-27-2020, 11:36 AM
BobTurner BobTurner is online now
The builder signs off the first condition inspection, prior to the A/W inspection. After that, it has to be one of the last two -repairman or A&P. And FAA policy is to issue no more than one repairman certificate for a given airplane, and then only to an original builder.
