Old 12-22-2015, 12:39 PM
JamesClarkIV JamesClarkIV is offline
Default Polish Prior To Vinyl Wrap
I've got 5 flights on my new RV7A and am bothered by the surface condition after 8 years of building (minor scratches and surface oxidation where I removed the blue covering for rivet lines but left the blue covering for extra years on the major areas between rivets.
I'm inclined to try slowly wrapping the plane in vinyl over time, but would like to do something now to immediately improve the surface condition for the next year or so.
Are there any problems with polishing for a year prior to wrapping? Would a freshly polished surface be a good starting point for a DIY vinyl wrap?
I hear votes for not polishing prior to painting, but what if I intend to wrap.
Jim Clark
Old 12-22-2015, 12:41 PM
Default Partial polish
Is it possible to only partially polish a plane to 80% solution (get rid of majority of surface crud, but stop short of mirror finish)?
Old 12-22-2015, 01:24 PM
scrollF4's Avatar
scrollF4 scrollF4 is offline
Moderator, Asst. Line Boy
Jim,
What you do now with your skins won't matter much when it comes time to wrap. If you hire a good reputable wrap company (like AircraftWraps.com) they're going to scrub that airplane clean at wrap time. They don't scuff the alclad, but they do get any/all surface treatments like wax etc. off the airplane. There's no need to paint or prime, and you really don't even need to fill pinholes.
http://www.vansairforce.com/communit...d.php?t=132000
So if you're going to fly her naked for a year, and you want a polished airplane, go ahead.
Scroll
Sid "Scroll" Mayeux, Col, USAF (ret)
52F NW Regional/Aero Valley Airport, Roanoke TX (home of DR's Van Cave)
"KELLI GIRL" N260KM RV-7A tipper
Catch her on YouTube's "Because I Fly!" channel
Proud and grateful 2020 -=VAF=- Contributor
Old 12-22-2015, 04:39 PM
BruceEicher's Avatar
BruceEicher BruceEicher is offline
Jim Clark
I agree that polishing prior will not cause problems. Many of us have done this also because half the plane is color, half polished.
But...IMHO...a good vinyl finish is much less work than a fair polish finish. Both have about the same learning curve, but vinyl will stay looking good longer and cause much less mess in your hangar.
Bruce, Katie, Hana and RV-8 HulaGirl
Old 12-23-2015, 09:29 AM
Rupester Rupester is offline
The Purple Polish by California Custom will do a nice clean-up job on a dull or lousy looking aluminum surface - and without an egregious amount of labor.
Terry Ruprecht
RV-9A Tip-up; IO-320 D2A
S. James cowl/plenum
(Dues paid thru Nov '18)
Old 01-04-2016, 09:36 PM
Default Started Polishing
I started polishing my RV as a complete newbie using:
6" Griots Random Orbital with red foam pad covered by zwipes microfiber cloths. See here: First Attempts at Polishing
Bob mentioned that better microfiber towels from perfect polish are available.
I recently ordered some purple polish, and green deoxidizer. So we will see how that goes. So far, I have been using a liquid aluminum polish that I picked up from autozone. Will post a picture of it next time I'm at the hangar.
Wondering if anyone has experience using the random orbital with the purple polish, or if everyone is doing this by hand?
Jim Clark
2015 RV7A
Manassas VA
Aircraft Blog: jamessclarkiv.com
Old 01-05-2016, 09:42 AM
I applied the Purple Polish by hand, but in some areas followed up with Grade S Nuvite and the Cyclo polisher. It looked VERY good ... Not as deep a shine as the full Nuvite process, but good enough to impress all onlookers except hardcore polish mavens.
Terry Ruprecht
Old 01-05-2016, 12:40 PM
RONSIM's Avatar
RONSIM RONSIM is offline
Default Help me understand, please
It is my understanding that, to get a polished shine, you have to remove the thin coating of alclad, which is the corrosion protection for the 2024 AL -- once the alclad is removed, a corrosion-protection material must be applied (paint, etc.), OR, constant polishing, waxing and corrosion prevention is required.
True, or not true?
Thanks (and after watching some of my neighbors' periodic polishing, I'll take paint anytime)
Regards,
Ron
RV-10 Co-built, maintained, flown (sold)
RV-8A Maintained and flown (Sold)
RV-6A Bought and Flying (N177RV), upgrades $$$
IO360, 180HP/CS, AFS 5600T, D10A, G650, G430, G327, ADS-B, VIZ385 AP
Very Happy Contributor
Comm, SMEL, CFII, A&P
Based at KCLW (Clearwater, FL)
Old 01-05-2016, 01:10 PM
krw5927 krw5927 is offline
The clad layer of commercially pure aluminum is what takes the good shine and also provides corrosion protection. You do not actually remove the clad when polishing.
Kurt W.
RV9A
FLYING!!!
Old 01-05-2016, 06:02 PM
Default Before and after, 2 minutes by hand:
I'm a brand newbie at this, but its fun. Not an example of the best job; just what you can do really quickly:
See here: Equipment I used to start
Jim Clark
2015 RV7A
Manassas VA
