Old 02-19-2020, 08:15 AM
RViator60 RViator60 is offline
Default Pitot and AOA routing
I'm installing a GAP26 heated pitot/AOA and can't find any description in Van's plans on how they are ultimately routed from the left wing through the fuselage. I'm running red and blue 1/4" plastic tubing and thought I could terminate these with bulkhead fittings on the wing root aft of the main spar to ease wing attachment. I'm interested in how other RV14 builders have done this.
Marty Guinn
Based at KSUT, Southport, NC
- 1973 PA28-180 (N55087)
RV14A Build
- Started Sep19, Aft Fuse complete
- Wing assembly underway,
- IO390 ordered (Oct20 deliv)
- Hartzell 2-blade composite on order.
https://eaabuilderslog.org/?s=MartysRV14A
Old 02-19-2020, 08:47 AM
rocketman1988 rocketman1988 is offline
Default Tubes
In my -10, I used bulkhead fittings to pass through the fuselage sides. Push to connect fittings were installed in the bulkhead fittings.
Bob
Aerospace Engineer '88
Structure - 90% Done
Cabin Top - Aaarrghhh...
EFII System 32 - Done
297 HP Barrett Hung
ShowPlanes Cowl with Skybolts Fitted - Beautiful
Wiring...
Dues+ Paid 2019,...Thanks DR+
Old 02-20-2020, 02:30 PM
jdmrv7a jdmrv7a is offline
I also used push to connect fittings. Cut the lines very clean at 90 degrees.
I would high recommend grounding the heated pitot and the lights using a shielded wire that runs back to your main battery ground bus. If you are using the Van's recommended GMU 22 mounting bracket make sure you use the Garmin copper screws and read the direction on other metal parts located near the GMU 22. You are trying to void any "magnetic anomaly" warnings after you install your avionics.
RV14-A QB
Factory Lycoming IO390 X, HZ CS 2 Blade,
Garmin Dual G3X 460, GTN 625, A/P 507,
GTR 200 & 20 COMM's, 245 audio, GTX 45R
Repairman Certificate
