Old 02-12-2020, 05:52 AM
rmartingt's Avatar
rmartingt rmartingt is offline
Default Alternator bracket for 2.25” lug?
I’m using a Denso automotive alternator as my primary and it has a 2.25” main mounting lug (I believe this is the “large” Denso frame?). Anyone know what the right mounting bracket is for this? Or am I in “fabricate your own” territory?
Engine is a wide-deck O-360.
RV-7ER - finishing kit and systems installation
There are two kinds of fool in the world. The first says "this is old, and therefore good"; the second says "this is new, and therefore better".
Old 02-12-2020, 08:33 AM
lr172 lr172 is online now
can't really help, but can advise that there is some variation out there. I made custom brackets (used the stock commonly available U bracket that bolts to case). I made a copy for a buddy installing the same denso alt on a wide deck and they wouldn't fit.
Also, that U bracket has 7/16 holes and the denso alt has 3/8. I used bronze spacers/inserts to tighten it up.
N64LR
RV-10 in Phase I
Old 02-12-2020, 10:13 AM
Kent Ashton Kent Ashton is offline
A bracket would be hard to bend up from one piece of flat stock and get the dimensions right. I have made them from two pieces of 1/4" mild steel angle. Drill them for the long mount bolt then cut the other legs of the angle to get the correct length and weld them together.
Old 02-12-2020, 02:57 PM
rmartingt's Avatar
I like that idea and I have the equipment... I'll just need to make a few test pieces to get my welding up to snuff! I'd imagine I could get a few out of just a foot or two of angle.
Old 02-12-2020, 04:37 PM
McStevens McStevens is offline
I'm wondering the same thing with my non-standard alt. Figured I could bend one myself with some heat. Not sure how I feel about welding two angles together given the environment and importance of this thing.
Old 02-13-2020, 08:26 AM
Yeah, I have thought the same about engine-mount tubes. :-)
Old 02-13-2020, 08:47 AM
9GT's Avatar
9GT 9GT is offline
I fabricated and welded the alternator bracket out of steel I had in the scrap bin for my RV-10.
David C.
Howell, MI
RV-9A: Under Construction.
RV-10: Completed 12/29/2013 SOLD 08/23/2016
"Donor Exempt" but donated through Dec. 2020
Old 02-13-2020, 11:06 PM
Heh. Fair enough.
