Old 02-12-2020, 04:54 PM
Sam_B Sam_B is offline
Default Firewall pass-thru
For getting cables and wire through the firewall, I like the idea of the doubletree ball pass throughs, but they’re a bit spendy. Seeing as how I own a lathe, and a milling machine, I was thinking of making something similar, since I have the stock around, and just have to take the time to cut it. I was thinking of making a tapered collet, a tapered hole for said collet to nest into, and a cap to squeeze the collet into the hole and tighten it to whatever wire/cable/plumbing needs to pass through the firewall. Slather it in the 3M fireproof adhesive before it all goes together to fill in the cracks. So my idea may be well intentioned, but not work in the real world, so I was looking for opinions here.
RV-8
Empennage done
Wings 90% done
Fuselage in progress
2019 dues paid
Old 02-12-2020, 05:56 PM
rocketbob's Avatar
rocketbob rocketbob is offline
I turned a stainless flange on my lathe, riveted that on the left side of the firewall and passed all three cables thru one hole. Fill the flange with firebarrier. Simple and cheap.
Please don't PM me! Email only!
Bob Japundza CFI A&PIA
N673AC RV-7 borrowed horse
N678X F1 Rocket, under const.
N244BJ RV-6 "victim of SNF tornado" 1200+ hrs, rebuilding
N8155F C150 flying
N7925P PA-24-250 Comanche, restoring
Not a thing I own is stock.
Old 02-12-2020, 07:23 PM
Larry DeCamp's Avatar
Larry DeCamp Larry DeCamp is online now
Default Yes machine or fab a bushing.
+1 for Rocket Bob suggestion. Dan H helped me years ago and the little T bushings riveted and sealed with firebarrier are flawless.
Larry DeCamp
RV-3B flying w/7:1 0320 / carb / Pmags / Catto 3b / Steam
RV-4 fastback w/ Superior roller 360/AFP/G3X/CPI/Catto3b
Clinton, IN
Old 02-12-2020, 08:58 PM
Carl Froehlich's Avatar
Get the nice SS passthrough flange that comes in the RV-14 kit. Put a piece of fire sleeve inside the flange and a piece over the top of the flange on the firewall side. Wire runs in the middle of course.
Old 02-12-2020, 09:20 PM
fl-mike's Avatar
fl-mike fl-mike is offline
I’m using these with the Rocketbob fill.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
They are welded stainless.
Mike W
Venice, FL
RV-6A. Mattituck TMX O-360, FP, GRT Sport EFIS, L3 Lynx NGT-9000
N164WM
N184WM reserved (RV-8)....finishing kit in progress. Titan IOX-370
Old 02-13-2020, 05:49 AM
Northernliving Northernliving is offline
Is this the firebarrier you are using for fill?
https://www.aircraftspruce.com/catal...l2000caulk.php
Brian J.
Boston, MA
RV8 Based at ORH - Purchased
RV8 - The Project #83313 - Under Construction
Old 02-13-2020, 07:40 AM
Brdog42 Brdog42 is offline
Those who used this method for electrical wiring...
Did you use the same method for control cables? Throttle, mixture, etc.
Thanks for sharing something simple that works!
Tim
1973 A150L sold
RV-6A restoration in progress
KCHD AZ
‘’’’’’’’’’’__|__
*>—O-(_)-O—<*
Old 02-12-2020, 09:40 PM
Default Little T bushings?
By ‘little T bushings’ do you mean the ones that come with the Vans kit?
RV-8
Empennage done
Wings 90% done
2019 dues paid
