Old 02-04-2020, 08:02 AM
noelf noelf is offline
Default Formation Flights and ADSB
The FAA has released a new Advisory Circular 90-114B on the use of ADSB. Section 4.3.1.3 covers use during formation flights.
Noel
RV-6A N6NF
tip-up
flying
Old 02-04-2020, 08:12 AM
vlittle's Avatar
vlittle vlittle is offline
This is the relevant info:
4.3.1.3 Formation Operations. ATC uses established transponder and ADS-B transmission procedures when participating in formation operations. Per the Aeronautical Information Manual (AIM) paragraph 4-1-20, if the formation flight is receiving ATC services, pilots can expect ATC to direct all non-lead aircraft to “STOP SQUAWK,” and should not do so until instructed. For visual flight rules (VFR) formation flights not receiving ATC services, ATC directs that only the lead aircraft should squawk the assigned beacon code (1200). All other aircraft should disable transponder and ADS-B transmissions once established within the formation.
V
V e r n. ====
RV-9A complete
Harmon Rocket complete
S-21 wings complete
Victoria, BC (Summer)
Chandler, Az (Winter)
Old 02-04-2020, 12:29 PM
RV8JD's Avatar
RV8JD RV8JD is offline
Already being discussed in this thread:
http://www.vansairforce.com/communit...d.php?t=177294
Carl N.
Arlington, WA (KAWO)
RV-8, 675 Tach Hours
(Pic 1),(Pic 2)
(Pic)
Glasflügel Standard Libelle 201B - Sold
Rolladen-Schneider LS1-f - No longer owned
