Old 04-24-2018, 02:20 PM
dweyant dweyant is offline
Default Aerosport Rudder Trim
I just completed the condition inspection on my RV-9A.
I usually do an improvement project or two as part of the condition inspection, and this year, since I finally got the plane painted I wanted to add a rudder trim (rather than the trim tab I forgot to get painted).
I ordered the Aerosport Products trim tab. One of my neighbors, had just installed one on his RV-10 and loved it.
After I didn't receive it for a week or so I called Aerosport power to check on the status. They said, the were in the process of redesigning the unit and using a 3D printer rather than machining the assembly, and asked if I would be willing to try out the new version.
I have some experience with 3D printers, and I was a bit skeptical of the strength of the printed parts, but I figured why not, lets give it a try.
I have to say I'm impressed with the strength and quality of the parts. They are printed using a nylon process, and while I didn't attempt to break the anything, they have a significantly stronger feel than the ABS printed parts I have done.
The install was a bit of a pain (mostly the crawling under the panel of my RV-9A), but straightforward enough and didn't take very long.
Overall, I'm quite please with the update, and continue to be amazed by what the 3D printing technology is doing.
-Dan
Dan Weyant
RV-9A N96KD
Done and Flying 4/30/2015
Old 04-24-2018, 03:15 PM
pazmanyflyer's Avatar
pazmanyflyer pazmanyflyer is offline
I have one of the machined versions and have not yet installed it on my 7. Will you please post pictures so we can 1) see new version of system 2) installation of new system. Besides materials I'm curious to know more of this redesign.
Carlos in Arizona
EAA Chapter 538 President, www.538.eaachapter.org
Wittman Tailwind W8 N53CH (built & sold)
Pazmany PL-1 N2029 (bought & sold)
RV7 - N537TC (reserved & building)
Emp, Wings & Fuse done - working on FWF
"The air is an extremely dangerous, jealous and exacting mistress. Once under the spell most lovers are faithful to the end, which is not always old age." - Winston Churchill
Old 04-24-2018, 08:38 PM
Aerosport1's Avatar
Aerosport1 Aerosport1 is offline
Here are some pictures of the new Aerosport Products Rudder Trim System. The system works just like the old system and mounts in the same holes. We feel after testing they will be a much better unit with a lot less parts. We redesigned this unit to be 3D printed on Our HP printer. We went from 27 parts to 7 not including hardware. They are also about half the weight as the old ones. We are still doing some Beta testing but we will start shipping these soon.
The cost will be
$195.00 plus shipping. Call us to purchase one.
http://www.aerosportproducts.com
Geoff Combs
RV-10 N829GW 775hrs
1940 Piper J3 Cub
Old 04-25-2018, 05:43 AM
falcon900guy falcon900guy is offline
will it work with the controlapproach rudder pedals? there aren't two torque bars like stock vans rudder pedals.
Old 07-30-2018, 06:55 PM
Rbb469 Rbb469 is offline
Default Any updates on the new version?
The cost will be
Just curious if the beta test is complete? Iím wanting to order one.
Dues gladly paid!
Old 07-30-2018, 10:10 PM
Default Control approach pedals
It would seem that it could work with the CA pedals if Aerosport could adjust the tube diameter on the arms...
Bob
Aerospace Engineer '88
Structure - 90% Done
Cabin Top - Aaarrghhh...
EFII System 32 - Done
290 HP Barrett Hung
Wiring...
Dues Paid 2018,...Thanks DR+
Old 07-31-2018, 10:00 AM
Aerosport1's Avatar
We can adjust the diameter. We just need to find out what that is. If someone has that information send it to me at geoff@aerosportproducts.com.
Geoff Combs
RV-10 N829GW 775hrs
1940 Piper J3 Cub
Old 07-31-2018, 11:19 AM
RandyAB RandyAB is offline
I'll measure it for you now Geoff if you could tell me exactly where the measurement needs to be taken. I would love this product on my airplane.
______________________
Randy P.
1st time builder
RV10 - Empennage (Started March 2017)
St. Albert, Alberta, Canada
2017 dues paid
Reserved:C-GRPY (GRumPY)
