Go Back   VAF Forums > Main > Reviews
Old 04-16-2018, 02:24 PM
goanddo goanddo is offline
Default A huge thank you to Bill at Up North Aviation!!!
Just a quick thank you to Bill at Up North Aviation. Bill does an AMAZING job!!! I drew a sketch of what I wanted my panel to look like. He emailed back immediately a full scale pdf file that I printed. I used this full scale paper to check to make sure the garmin products would all fit nicely with each other and the structure behind them. I then asked bill to move things around a 1/16th here and 2 inches there. Butta bing, butta boom!!! My panel showed up a few days later perfect. Things could not have been easier. Thank you Bill!!!
Most grateful,
Ron
edit.....I reached Bill at www.upnorthaviation.com
Old 04-18-2018, 09:52 AM
marv1121's Avatar
marv1121 marv1121 is offline
Ditto. Bill cut a new instrument panel for my RV-4. He even suggested a couple of changes that I really liked and had not thought of. The panel fit like a glove and all of the instrument mounting screw holes were perfect. I could not be happier with it. Rather than paint it, I covered it with a very thin layer of carbon fiber material which is very tough and will resist scratches much better than paint. Here are some photos ranging from the bare metal, new panel to the final finished product in the airplane. Go see Bill, you will like his work.
Marvin Homsley
www.smoke-system-helper.com
419-360-7414
marvin@buckeye-access.com
Old 04-19-2018, 09:50 PM
wjb's Avatar
wjb wjb is offline
+1 ... Bill did a great job on my -7 panel
Bill Bencze
N430WB (reserved) RV-7 #74152, tip-up. Working the baffles
Log at: http://rv7.wbencze.com
Defeating gravity one rivet at a time
VAF 2019 donation happily made
