Old 10-19-2018, 08:17 PM
sglynn's Avatar
sglynn sglynn is offline
Default First test of CS prop. Not sure its working.
So I'm not sure my new constant speed prop is working. I'm almost done with RV-7A with IO360 engine and prop from Van's. I did the second idle test today to make sure both mags are working and to see if CS prop is working. I stayed at 1000 "RPM and only ran engine for a couple minutes to keep temperatures low until I'm ready to break in. But at 1000 RPM I pulled the Prop cable like I do on my Cherokee at 2,000 RPM and looked for RPM slow down. I got no change. I pulled a little farther, no change. I didn't get any noticeable difference pulling the prop back at idle. Shouldn't I though? I checked the cable and yes it is pulling the governor fully. And yes I can twist the blades by hand. Maybe there is a lot of new oil that needs to run up into the hub and I didn't give it a chance.
So, what's your experience? How does the first tests of your CS Props go? What do you think I should try in order to make sure it is hooked up properly and working?
thanks
Steve Lynn
RV-7A
100% Complete
Airworthiness Certification Complete
First Flight in January 2018
Anacortes, WA
www.mykitlog.com/sglynn
Old 10-19-2018, 08:19 PM
BillL BillL is offline
Try it at 1700 before getting concerned. It may take a while to get the air out and fill the passages with oil. 4 or 5 slow pulls all the way out. Mine really jumps when pulling the prop and hard to hold, so be ready.
Bill
1st Flight 1-27-18
Phase II 8-3-18
Repairman 11-15-18
Instrument Currency 12-17-18
Old 10-19-2018, 08:51 PM
Ironflight's Avatar
VAF Moderator / Line Boy
Our four C/S Prop installations all have different “minimum reaction RPM’s”. One you can cycle at 1800, one has to be at 1850, another wants 1900, and the fourth won’t cycle until you get it to 1950. None of them would even come close to cycling at 1,000 rpm.
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
Old 10-19-2018, 09:45 PM
pilotkms pilotkms is offline
My Hartzell prop with Hartzell governor will NOT cycle at 1300 or below. I havent looked for the exact rpm spot where it transisions but it will cycle at 1600 and above.
Keith
RV 7A RV #9700
N325KS the Flying K
Built in SoCal KCCB, now @ KPXE
250+ Hours & 5x cross the USA
2018 OSH - yes
Old 10-20-2018, 07:50 PM
airguy's Avatar
airguy airguy is online now
My Whirlwind prop (Jihostroj governor) won't pay attention below about 1400 rpm, and then very sluggishly. On top of that you've got large air bubbles in the system with a new install that you will have to purge with a few cycles first.
Start with a cool engine and get the rpm up around 1800 and give it a few seconds, I think you'll be fine.
Greg Niehues - PPSEL, IFR, Repairman Cert.
Garden City, TX VAF 2019 dues paid
N16GN flying 360hrs and counting! Built an off-plan 9A with too much fuel and too much HP. Should drop dead any minute now.
Old 10-21-2018, 09:02 PM
gmcjetpilot's Avatar
gmcjetpilot gmcjetpilot is offline
Ditto the prop will not change pitch at low RPM... as folks say above. I don't think there is a specific RPM it will work or not work... it is a function of oil pressure. I would not attempt to cycle the prop at low RPM. The min should be run up RPM, 1700 RPM.
George
Raleigh, NC Area
RV-4, RV-7, ATP, CFII, MEI, 737/757/767
Old 10-21-2018, 09:11 PM
Bicyclops Bicyclops is offline
I didn't bother cycling the prop til I had an hour on the engine. First flight I just left everthing forward and worked on breaking in. When it came up to 2700 on the takeoff roll, I figured that it was working well enough and left it alone. Why draw oil pressure away from servicing the bearings before they even have a chance to begin wearing in?
Ed Holyoke
Old 10-22-2018, 06:14 AM
schaplerrh schaplerrh is offline
CS props at low rpm (low MP) work like a fixed pitch propeller so there’s going to be no rpm change without a throttle change at lower power settings.
