Old 10-18-2018, 09:32 AM
Charles in SC Charles in SC is offline
Default Oil seperator questions
Sometime back I purchased and installed an RMJ AERO oil seperator. Two questions for those that have them. The crankcase vent is a 5/8 and the seperator intake is a 3/4. What is a good way to make the transition without welding a new intake spout on the seperator? I cannot find a fitting for the engine side that looks like it will fit. Also what is a good way to connect the oil return to the engine? I have a return line from Anti Splat with a fitting welded in it but after looking at it awhile I am not sure I like that idea. The seperator came with a little strap with a tube in it to put in the oil dipstick but I am not sure I can get enough fall for it to drain properly. The seperator is mounted as high as I can go on the firewall. I have an IO 360. Thanks for any input!
Aircraft structure built.
Going at a snail's pace, life gets in the way.
Wiring done.
Engine hung.
Working on cowling.
RV 7
Old 10-18-2018, 10:16 AM
DanH's Avatar
DanH DanH is offline
https://www.homedepot.com/p/SharkBit...7LFA/202798048
The accessory case has a turbocharger oil return port down low on the right side, usually plugged with a 3/8 NPT allen pipe plug, #13 below
Dan Horton
RV-8 SS
Barrett IO-390
Old 10-18-2018, 11:09 AM
Thanks Dan I will look for that fitting on tha accesory case. Also I know about that kind of reducer like the Home Depot one you linked but if I use something like that there is not going to be much hose left for flex. Also I try to stay away from hardware store parts.
Wiring done.
Engine hung.
Working on cowling.
RV 7
Old 10-18-2018, 11:53 AM
On Ed's RV8, we downsized the separator stubs fittings to 5/8 in the crimper, and he then clamped his hose onto the separator.
Tom
It would be nice if they had AN males on them--
Ridgeland, SC
Old 10-18-2018, 12:02 PM
DanH's Avatar
It's a breather hose. That brass reducer will not be a problem...but for the low, low discount aviation-grade price of $50 (that's right folks, believe it or not, only 5% of an AMU!!), I will cheerfully machine one to your drawing, from 6061-T6
Dan Horton
RV-8 SS
Barrett IO-390
Old 10-18-2018, 03:11 PM
airguy's Avatar
airguy airguy is offline
Oooohhhh!! That's military-grade, right?
Greg Niehues - PPSEL, IFR, Repairman Cert.
Garden City, TX VAF 2019 dues paid
N16GN flying 360hrs and counting! Built an off-plan 9A with too much fuel and too much HP. Should drop dead any minute now.
Old 10-18-2018, 07:28 PM
Thanks for the offer Dan, I will make my own if I decide to go that route.
Wiring done.
Engine hung.
Working on cowling.
RV 7
