Old 10-08-2018, 12:17 PM
smt6 smt6 is offline
Default AOG
Stuck AOG at SNA. Engine fires but then chokes out. All the obvious has been checked. O-360 with dual electric ign. Out of ideas. Any help?
Old 10-08-2018, 12:20 PM
N941WR's Avatar
N941WR N941WR is offline
Which ignition?
If P-mags, give me a call. (Check your PM's.)
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
Old 10-08-2018, 12:54 PM
airguy's Avatar
airguy airguy is offline
What do you mean by "chokes out"? Too rich to run?
Greg Niehues - PPSEL, IFR, Repairman Cert.
Garden City, TX VAF 2019 dues paid
N16GN flying 450 hrs and counting! Built an off-plan 9A with too much fuel and too much HP. Should drop dead any minute now.
Old 10-08-2018, 01:15 PM
N941WR's Avatar
I just got off the phone with him.
The engine starts right up but dies as as if it is fuel starved as the RPM's start to rise.
He has an Ellison throttle body and dual Fly Efii system 32 ignitions.
I've got no experience with either.
Bill R.
SC86 - Easley, SC
Old 10-08-2018, 02:22 PM
flightlogic's Avatar
flightlogic flightlogic is offline
Is there a gascolator in the system? Possible fuel blockage...
Pull the fuel caps and see if there is a vacuum...
"Kindness is never a bad plan."
Work bio: Avionics tech support; ATP rated in planes and Helicopter Instructor law enforcement tactical radio systems. Blessed to fly my RV9A to work every week.
Old 10-08-2018, 03:14 PM
There is a gascolator. The gascolator drains well when I sump fuel.
Old 10-08-2018, 03:15 PM
Still looking for ideas.
Old 10-08-2018, 03:16 PM
Getting as high as 1300rpm prior to engine quitting
Old 10-08-2018, 03:39 PM
oaklandaviator oaklandaviator is offline
Default Mixture cable
Is the mixture cable attached and going full throw both ways? If so, try pulling the filter screen which is under the fuel inlet of the Ellison. Ensure good fuel flow with the line disconnected. Look up the throat and ensure the mixture tube rotates when the mixture control is moved. Holes point down at cutoff and are 90 degrees at full rich. In that same vein, ensure the mixture lever on the Ellison has not come loose. It should be safetied, but you never know. That could cause the mixture tube not to rotate.
If it's an older EFS 4-5 (O-360) or any EFS-4 there should be a small tube running from the bottom of the bell inlet to the regulator. I believe the newer EFS 4-5 have this incorporated internally so wouldn't apply.
Just a few thoughts.
Old 10-08-2018, 03:55 PM
n18pf's Avatar
n18pf n18pf is offline
Default Induction leak?
Check your induction system for a leak. For example one of the hose clamps may have come loose and slipped off the induction tube. You'll want to check all four cylinders. If you are sucking air the mixture will go lean and the engine may die. Although usually it runs rough before it dies.
Also check the fuel lines. Remove the line from the throttle body and see if it flows properly. You can't tell if the gascolator is plugged by draining the gascolator. I believe the screen is on the other side of the drain. Personally I would pull the gascolator screen and inspect it visually. Also is there a screen in the throttle body like there is in a carburator? If so visually inspect that too.
Just my $0.02 worth (and probably worth much less than that!)
Good luck!
Paul A. Fisher
RV-7A N18PF
Q-200 N17PF
APRS track
