Old 09-11-2018, 12:39 PM
MED MED is offline
Default Condition Inspection Timing
How (when) is the condition inspection timing determined? If (optimistically speaking here) I receive my airworthy certificate in the Fall, am I required to have all future condition inspections in the same month or can I "reschedule" my condition inspections for a slower flying time, like February?
MED
140236
N435MD reserved
Old 09-11-2018, 12:52 PM
You may always do them early. Or, you may do them late, as long as the aircraft doesn’t fly after the previous expiration date (always the last day of the month). Or, slip it one month at a time. e.g., if your initial a/w inspection is Oct 10 (expires Oct 31 following year), start your next CI on Nov 1, sign off completed on, say, Nov 5. Following year, start inspection on Dec 1, etc., until you are in the desired month.
Old 09-11-2018, 01:30 PM
airguy's Avatar
airguy airguy is offline
Proper planning with the calendar allows this to be a 13-month event, essentially.
Greg Niehues - PPSEL, IFR, Repairman Cert.
Garden City, TX VAF 2019 dues paid
N16GN flying 360hrs and counting! http://websites.expercraft.com/airguy/
Built an off-plan 9A with too much fuel and too much HP. Should drop dead any minute now.
Old 09-11-2018, 01:52 PM
Mel's Avatar
Mel Mel is offline
All the above information is true. On the other side of the coin, I often do more than one condition inspection per year.
If I have the aircraft substantially apart for any reason, sometimes I will go ahead and pull it the rest of the way down and do a condition inspection even though it is not time. There is no requirement to wait 'till it is due.
A&P/EAA Tech Counselor/Flight Advisor/Nat'l Test Pilot School
<rvmel(at)icloud.com>
North Texas (8TA5)
Legend Cub purchased 12/2017
FRIEND of the RV-1
Eagle's Nest Mentor
Old 09-11-2018, 03:47 PM
MED MED is offline
Thanks to all. Looks like there will be a way to move it to a slower month, eventually.
MED
140236
N435MD reserved
