Old 04-27-2018, 11:23 AM
Default Refining Prop Pitch...
Iím trying to find optimum prop pitch for my RV-12/912 ULS/320TT. Most of my flying is below 4000 MSL and airport is 870 MSL grass runway. If Iím going somewhere Iíll flight plan ~ 7000 MSL.
Iíve been adding a couple tenthís degree pitch and today I have performance listed in table below with one person aboard and half fuel.
Engine is running smooth and seems happy. Temps are all good.
Question - Do you think 4920 rpm is too slow for full power climb?
Hinckley, Ohio (1OA2)
EAA #499867
RV-12 Bought Flying Oct 2015 with 48TT - Hobbs now 459
LSRM-A Certificate 2016
MJ Stricker (Father & CFI) - 1st Lt. Captain B-17H
Old 04-27-2018, 01:11 PM
I do.
You have likely crossed over to the coarse side of ideal, where additional pitch wont really give you any more speed but will degrade climb.
Scott McDaniels
Hubbard, Oregon
Old 04-27-2018, 02:23 PM
Driftdown Driftdown is offline
For overall best performance (climb and cruise) the best RPM is 5600-5650, set at wide open throttle (WOT), flown straight and level, at your typical cruise altitude. Here in Florida, that is 3500 ft MSL for me.
Old 04-27-2018, 04:23 PM
scottmillhouse's Avatar
scottmillhouse scottmillhouse is offline
I agree, way too coarse. I wasted a lot of time way over pitching mine but at that climb RPM I was seeing 128 knots at 5500 with Dynon Betty yelling at me for going too fast. Flattened a lot to about .2 coarser than Van recommends getting about 5080 at 75 knots but I climb after initial about 85 closer to 5200. My SNF trip at 3500' solo I was seeing 120 TAS at around 5360 at 25.4 MP. Hot weather and time will tell on climb performance but for now it appears I gained about 5 knots in cruise for my long cross countries from my initial pitch setting.
At this pitch I'm also getting 5600- 5700 WOT at around 3500', goes to redline above.
Scott- 2019 dues paid
New RV-7A N579RV first flight 6/26/2019, now in phase I
RV-12 N319RV 1st flight 12/2015, 310 hours probably on display for sale at Oshkosh
Purchased RV-12 sold, RV-9A- 536 hours sold, RV-7 sold, Kitfox sold
Old 04-27-2018, 05:38 PM
DHeal DHeal is offline
Over-pitching your prop has the potential to damage your engine. See Figure 1 of ROTAX's SL-912-016R1 at:
https://legacy.rotaxowner.com/si_tb_...912-016-r1.pdf
I use the numbers Driftdown noted above and am happy with the balanced climb/cruise performance.
EAA #23982 (circa 1965) - EAA Technical Counselor and Flight Advisor; CFI - A&I
RV-12 E-LSA #120496 (SV w/ AP and ADS-B 2020) - N124DH flying since March 2014 - 790+ hours (as of July 2019)!
VAF donation through June 2020.
Old 04-27-2018, 10:35 PM
Phantom30's Avatar
Phantom30 Phantom30 is offline
Iíve played around both over and undered pitched....finding Vanís recommended pitch of 71.4 to be dead on for overall performance.
Finding a good digital level was a trip, but once I got one. I can dial in both blades to within .1 degree of each other.
Ric Dickison
307 (CAB) Phantom
Search and Destroy (Can
Tho RVN)
Distinguished Flying Cross Society Member
CH-47 & UH-1H "Driver"
Rotax 9 Series Service IRMT
RV-12 Kit#729 "N312RD" is now a full functioning fun machine!! Thanks Van for fulfilling my dream😎
2018 Dues Paid
Old 04-27-2018, 11:13 PM
Give us some performance numbers.
During straight and level flight, what is the maximum achievable engine RPM, when throttle is wide open?
At that maximum RPM, what is your indicated airspeed?
During the takeoff run, at full throttle, what is your RPM at rotation?
During climbout, at that RPM, what is the climb rate (and airplane weight)?
Old 04-28-2018, 06:35 PM
Phantom30's Avatar
Will give info in a few days...as iím On my way down from Idaho to get plane in Phoenix.
Ric Dickison
307 (CAB) Phantom
Tho RVN)
2018 Dues Paid
Old 04-29-2018, 05:15 AM
joedallas's Avatar
joedallas joedallas is offline
Default Best digital leval
Ric
I would like to know what digital level you used to get them that close.
Joe Dallas
Joe Dallas
Kit-#12400
www.joesrv12.com
www.EAA1298.com
Old 04-29-2018, 06:59 AM
DaleB's Avatar
DaleB DaleB is offline
I bought this one (https://www.amazon.com/gp/product/B006JR8XBG). It claims 0.05 degrees resolution with +/- 0.2į accuracy. Needless to say I was skeptical and ready to return it.
What I have found is that, while I can't speak to its absolute accuracy in every situation, it is dead on at 0 and 90, at least as close as I can test it. More importantly to me, its measurements are perfectly repeatable. The same angle will measure exactly the same, every time.
Dale
Omaha, NE
Previous RV-7 project (sold)
