Old 10-13-2018, 07:43 PM
dmat dmat is offline
Default Subpanel on a 6 tip-up structural?
Hi all, about to cut the subpanel almost in the middle of the subpanel and wanted to know if itís structural? There is a bracket that hold the 2 subpanel as together.
D
RV6A - N6389 - flying regularly
Old 10-14-2018, 09:52 AM
Snowflake's Avatar
If you're referring to the panel that is riveted to the top skin, and has longitudinal ribs riveted to it that extend forward to the firewall, yes, it is structural.
Rob Prior
Old 10-14-2018, 02:25 PM
gasman gasman is offline
D
It depends on how and where you are going to cut it. Sketch up the cuts and send them to Van's for their OK.
Properly reinforced, you can cut good sized chunk out of the center.
VAF #897
2017 =VAF= Dues PAID
