brian
I decided some time ago to not use the standard tipup canopy hinge pins and to use AN4 bolts instead, as popping the canopy in flight has never been tested (that I know of) and I decided it was all too iffy to bother with. Plus the linkage would interfere with my tight avionics placements. But, if I could replace those AN4 bolts with explosive bolts, that would give me the best of both worlds.
I know some military aircraft use explosive bolts in some applications. Is it possible to get explosive bolts anywhere, like in AN4 sizes?
thanks,
brian
thanks,
brian
