Old 05-18-2018, 09:13 PM
rjarrell's Avatar
rjarrell rjarrell is offline
Default 3 Blade lower cowl Mods
javascriptetail('{18A2F07B-FF8C-4F82-BAD1-55B8F8250A41}',0,'{4D5A29C6-E06D-4C76-A066-EDA96557F7F7}','')
Struggling with pix for now
Read a lot of post about the extended opening required for a 3 blade prop but had to guess at measurements. Sharing pix of my modification after swapping a 2 blade Whirlwind for a 3 blade Hartzell composite. Should be at the Hartzell display at Osh...oops Air Adventures this year if you want a closer look.
Removal is not fun but doable with two people, protect the blades by covering the hinge on top of the bottom cowl (I used brake tubing and trying different sizes of PVC trim from McMaster Carr) I'll share when I get it right.
Tie down the tail to lift the front wheel off the ground (chock the mains first). Tried it without this step and it can be done but very difficult, you pick up over and inch of clearance.
Cowl installation seems easier if you slide in from the side, tape up anything you don't want scratched up. Remove the front gear leg cover, pants can stay on.
Rodney RV-10 "LIBERTY"
Dues paid 2018
Old 06-12-2018, 10:37 AM
greghale greghale is offline
Default 3 blade lower cowl mods
I installed Rod Bower's Ram system on my RV10. Not only did it give me 1-2" of manifold pressure increase in cruise, it also makes it easier getting the lower cowl off around my 3 blade prop. A side benefit is you can remove the ram air duct and examine the bottom of the engine without having to remove the lower cowl.
I've got pictures on my web site http://www.nwacaptain.com/eng_induction.html
Greg...
Old 06-12-2018, 10:55 AM
AviatorJ AviatorJ is offline
I did what Greg did. Just make sure you get the correct Scoop from Rod if you go that route!
Justin
RV-10 Quickbuild 'Final Assembly'
http://operationrv10.blogspot.com/
Donated for 2018
Old 06-12-2018, 11:19 AM
ppilotmike's Avatar
This may be a silly question, but what are the benefits of going with a 3-bladed prop, besides the cool factor? Anybody want to lay out their version of the pros and cons of a 3-blade?
Mike Rettig
EAA Chapter 301, President www.eaa301.org
VAF Dues Current: Paid for 2019 on 12/03/18
RV-10 (41PX Reserved) Fuselage
http://www.mykitlog.com/users/index....ig&project=803
https://www.youtube.com/watch?v=zKCyX2FXrlw
Old 06-12-2018, 11:27 AM
rv7boy's Avatar
rv7boy rv7boy is offline
Forum Peruser
One quick answer is that for a well balanced propeller, the three blades at 120` are out of phase with the power pulses at 90`of a four cylinder engine, and the result is less vibration. But you know you can read anything on the internet.
Don Hull
RV-7 Wings
KDCU Pryor Field
Pilots'n Paws Pilot
N79599/APRS Automatic Position Reporting System
“Certainly, travel is more than the seeing of sights;
it is a change that goes on, deep and permanent, in the ideas of living." Miriam Beard
"It should be added that the sublime beauty of the facture brings within the realm of discourse the substructure of critical thinking. " -using Doug's Art Critique jargon link and my birthday, I get this!
Old 06-12-2018, 01:47 PM
MConner MConner is online now
Three bladed props “generally” feel smoother and have more ground clearance at the cost a a little speed and some added weight. YMMV
Old 06-12-2018, 02:32 PM
Auburntsts's Avatar
Maybe, but since we're in the RV-10 Forum it's a 6 cylinder engine not a 4 so the power pulses aren't 90 deg apart. I'd argue that the "perceived" smoothness comes more from the lower tip speed and vibration of the 3-bladed prop than anything else.
Anyway here's an old thread that sums up the 2 v 3 debate: http://www.vansairforce.com/communit...ead.php?t=1495
Todd Stovall
PP ASEL-IA
RV-10 N728TT - Flying!
WAR EAGLE!
Old 06-12-2018, 04:39 PM
ppilotmike's Avatar
Thanks Todd!
Mike Rettig
