CPSONE
The plans show two rivets in the outboard end (small end) of the trim tab that you put in after the folds are made. They are not pre-drilled. The one at the forward end is no problem but looks like there is not proper edge distance if you put a rivet anywhere closer to the trailing edge tying the two folds together. Anyone have the "proper" location for this second blind rivet?
I serached the forums and could not find anything...
