Old 11-04-2018, 03:41 PM
sritchie sritchie is offline
Default Cowl Camloc interference with rv10 engine mount - help!
Hey all,
Well, I should have read the forums for pitfalls. I've installed my flanges for my milspec camloc cowl installation, and I've just found that four of the flanges are placed so that the camloc receptacles will JUST interfere with the engine mount! (One of the four has a bit more overlap.)
I might be able to shift the location of the camloc on the flange for at least two of these, but I thought I'd ask, in case that's not possible -
Does anyone know of a lower profile camloc receptacle that I could use that wouldn't interfere with the engine mount?
Of course I can always just go with countersunk screws at these four locations, but I'd love to have a consistent look and camloc mechanism if possible.
Thanks all in advance!
Old 11-04-2018, 05:02 PM
Electrogunner Electrogunner is offline
Default Camlocs
I had to move a couple of mine for being alittle overzealous. No harm no foul. Just shift a couple to maintain spacing and clearance. Only you will know. Well and all of us too.😉
RV10 N620RV
IO540 C4B5
Whirlwind 375HRT
Garmin G900X
First Flight 2/14/2019
Old 11-05-2018, 07:54 AM
Lynnb's Avatar
Lynnb Lynnb is offline
Something to keep in mind, where they interfere with the lower mounts, you might just leave those out, I have the same issue and that is my plan, my top ones aren't interfering so can't help you on those.
RV-10 in Process
Old 11-05-2018, 10:00 AM
sblack sblack is offline
Floating recepticals or fixed? Fixed aren't as deep. I switched to fixed, moved the hole up 1/4" and ground a bit off one side of the receptical. My clearance is enough for a couple of human hairs but a miss is as good as a mile.
Scott Black
Old school simple VFR RV 4, O-320, wood prop, MGL iEfis Lite
VAF dues 2019
