Old 06-28-2019, 01:08 PM
N941WR's Avatar
N941WR N941WR is offline
I have a Sam James cowl and a Nerf football cut in half works grrafor the cooling inlets and a small Nerf football plugs the carb inlet perfect.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
Old 06-28-2019, 03:02 PM
airguy's Avatar
airguy airguy is offline
Bruce's custom covers does good work for those - for both the Vans and James cowl.
I'm on my second set now - only because the first set failed the 80-pound white lab chew-toy test.
Greg Niehues - PPSEL, IFR, Repairman Cert.
Garden City, TX VAF 2019 dues paid
N16GN flying 450 hrs and counting! Built an off-plan 9A with too much fuel and too much HP. Should drop dead any minute now.
Old 06-28-2019, 03:23 PM
Eddie P's Avatar
Eddie P Eddie P is offline
I am in the market for some plugs too. I like the "Bruce's Custom" product a lot in the photos. For the price delta between the Vans Covers and the Bruce's Covers ($100 difference, $55 vs $155) is there anyone who's seen both that can say there is $100 worth of difference?
Flying is Freedom
RV-8 IO-360 WW RV200 CS Prop KRNO
VAF Support / Dues Paid Through DEC 2019
Old 06-28-2019, 06:36 PM
Scott Hersha Scott Hersha is offline
A cheap alternative if you donít need to use them every day - a large yellow sponge from Walmart and other places like you would use to wash your car. Shaped like a loose figure 8. Squish it a little and it fills the cowl inlet tightly. You can poke a hole in the middle for a cord/strap and secured with a little shoe goo to tie them together if you want. If you donít use the cord mod, it serves as a cleaning tool for bugs when you get home. Let it dry and youíre ready to use it as a plug again. Thatís been my method for years.
SH
RV6/2001 built/sold 2005
RV8 Fastback/2008 built/sold 2015
RV4/bought 2016/sold/2017
RV8/2018 built/Flying
Cincinnati, OH/KHAO
JAN2019
Old 06-28-2019, 07:27 PM
donaziza's Avatar
donaziza donaziza is offline
Yep,----This sounds like exactly what I bought at Walmart. $1.99 each. Absolutely perfect fit for an RV 8. I also just bought two 16 inch "do not fly" red ribbon streamers to hang on the sponges. Those cost $7 each. Oh well-----------------
By the way, after cleaning out the bird's nest, I jammed a couple of old tee shirts in the cowl openings, until I could find something permanent. So yesterday, I go back to my hangar to see if the sponges fit, and what do I find?? A couple of leaves up against one of the tee shirts. That little sucker had been back, trying to redo his handywork.
