Capflyer
On the Berringer brakes & wheels (mains) I'm a little troubled by the way the flexible brake line from the caliper to the fitting in the Grove airfoil gear. Would love to see how others routed the lines so they don't rub agains the rotors. If I have the lines routed correctly they could probably be tie wraped to the gear leg but something a little more robust would be a better solution since this area is not visible under the wheel pants.
