My Nav (VOR part) radio on the 430W has decided to stop working. The setup is as follows:
430W with Val 429 as external CDI
Bob archer Nav antenna in each wingtip. left antenna nav & G/S for Val429
Right antenna nav & G/S for 430 W.
ILS and G/S work on the 430W VOR is flagged on the Val 429 when I go to the external signal.
I switched the antenna connections and 430W VOR signal is still not there so the problem is not in the antenna as Val 429 internal radio is fine.
HELP!!!!
John Morgan
HELP!!!!
John Morgan
