For you guys with the GRT HX EFIS/Garmin 430W/TruTrak Digi II VSGV combination, I have a question.
When doing a (vectors to final) gps approach, how do you set up the autopilot to fly the (ATC assigned)vectors while coupled? The only way I could do it was to switch out of GNAV and select HDG mode and then switch back once close to/at the final app course.
I did a little testing and the 430W will intercept the final course on its own(you just can't pick your own ATC assigned course), just be sure you are on the proper end of the runway or it will try to intercept the final course and fly away from the airport.
Any thoughts?
Any thoughts?
