dbaflyer
When I made the big cut I gave myself plenty of extra off the front bow. Anywhere from 1/4 inch down to almost nothing to be trimmed. So yeah it is not exactly straight from the left to right side Is it better to trim this off using a cutting disc or with a belt sander? I have made all my other cuts using a diamond cutting wheel in a dremel. If a belt sander what would be the lowest grit paper to use?
