OP-34 PDF
rapid_ascent
Does anyone have drawing OP-34 in PDF form that they could send me? I'd like to figure out the position of the heater valve on the firewall. I think that is shown on OP-34 from what I've read.
See DWG 19 in the construction plans. Position description D.
In my set the OP-34 is for the RV-8. For the 7 it is sheet 19 as mentioned. I believe you're looking for OP-29 with dimensions for location. PM me if you want an emailed copy.
PFfgTyX5vac-fl-rsQKLIU85b2zDI42biDLOsugRKfzofLgx32ttcrN3IcbjSDzp7qoA2ACo5Z9FgYKWtYTQz5WNEhfiWxCh_9IIjlNZIvU6OZN_526sIH14gB6iJKK8E3mWLEUqZ0IEpXdXyQ284DUtRCYPMWhBWSxZ_i07uo73srdoH1x2BnHDtq6nLeOZ5qCM3Rx8XqWtEXJvTuQ9PtuyZr1TdYZ5NbtlMNiDaL-MrrevXna371M-UEmPPKbMRCk7ttnyH-g2wcBpyDRdw8KEWkXatfvrAZDfcsh1Xky1PjINjcbIrpakWcBcBvMi9akh2gW4FqrCwplmO4iMTjMjS3HmBo2D1CvtWVANTjcLuvinZI4Bm0Sb68BbkBrBTDDbi3Ani6Vx_e_odXS6WKQOYsv52N-ItdopunQlFH3UkW-o3iZML0m4PH2mtEOlZdLjpeCamkwZI5Pn3wUecwbAToNsaKCZ-3_RQUOCC40B8tC-TxHe3nW_HS_Rbz2qZPf8WQdZ3ailB62nSsF0HnS-U9lAtOJKeuHFbfEx9e6UJbOJE_KXdMZ3m28avDcqVekuEf5HudeG1XRsWMHjDyUbcrbcuYo9eEo2Tmg=w1428-h946-no
