dan carley
I have the original non swivel tail wheel with a bolt holding the tire on. what is a good tow bar to use
thank you
dan carley
thank you
dan carley
I have the original non swivel tail wheel with a bolt holding the tire on. what is a good toe bar to use
thank you
dan carley
thank you
dan carley
I've been using a nylon strap from a ratchet strap. Works rather well and with the right length it stays well below the rudder.
Do you use something for a handle to pass through the ends? This seems like a simple/lightweight solution!
John
I bought a Tailwheel Transporter as they advertised their shortest RV height model compatible with all RVs, including the RV3. It didn't work. Didn't have the clearance. I called them and got the equivalent of an, "oh well" response. Basically they told me that when they advertise compatible with all RVs what they mean is all RVs except with the original Vans non-swiveling tailwheel. Oh. Nice to know after the fact. Over $200 of scrap metal gathering dust in the corner of the hangar.
Jim
