I fitted up my cowling on the weekend. The fairings on either side of the air exit tunnel (bottom of fwd fuse) which are called F451 (left and right) start 1" behind the firewall. So when you mount the cowling, which is even or slightly ahead of the FW (because of the flange) you have a gap all around the front of the F451. some of that is taken up by the gear strut, on the bottom and outside, and that will be covered by the upper gear strut fairing. But the inside of that gap seems to be wide open and rather unsightly. I poured over the plans trying to figure out what I was missing and I have not found anything. I have no other 4s at my local airport to go look at. Anyone have any bright ideas? Pics would be even better.
thanks
thanks
