Finally,,,,,, the cabin top and doors are done. Im beginning to pull wire and harnesses. Any issues running the Garmin servo harness with the magnetometer harness, and master solenoid wire, tied together and in the same conduit to the tail. Any EMI. Also, how do you run wires through the tail bulkheads. Do you drill holes with bushings or?
