Go Back   VAF Forums > Avionics / Interiors / Fiberglass > GPS
  #631
Old 11-08-2019, 12:10 PM
swixtt swixtt is offline
Great, thanks for the update on the update. will stay tuned for the new release.
on a side note, is there anyway to increase 'tracking log line, breadcrumb' size on the Map or perhaps have 'tracking log line' or custom way-points appear on the Enroute Charts?
RV9.... Tail done. Inspection done! Wings pre-cover MDRA inspection done. Closing them up now. Fuse underway.
Old 11-11-2019, 01:15 AM
eld eld is offline
Default Clear recent tab
Hello Steve,
I have a bad recent point on this tab and I can't delete.
Do you know how to clear all point on Recent Tab ?
Eric
Old 11-11-2019, 10:17 AM
g3xpert's Avatar
g3xpert g3xpert is offline
Post Aera 660 V3.70 Software
Hello,
Aera 660 V3.70 software was released this morning.
Changes made from version 3.60 to 3.70:
  • Increase access to the symbol keyboard (e.g. for waypoint searches)
  • Fix Flight Log storage
  • Fix Navigation Database issues
  • General improvements to system operation
  • Includes GDL 39 software version 4.81
  • Includes GDL 5X software version 2.12
  • Includes GPS software version 3.30
Steve
Garmin G3X Support
g3xpert@garmin.com
Old 11-18-2019, 11:41 AM
Installing mine now.
Old 12-03-2019, 03:59 AM
gFlyer gFlyer is offline
Default Support of Century IIB Autopilot
Hi Steve,
is there a possibility to use the area 660 in combination of a G5 to steer with a GAD29 a Century IIB Autopilot? While the area 660 should be able to control the flight route?
Kind regards
gFlyer
Old 12-03-2019, 09:26 AM
g3xpert's Avatar
Post
Originally Posted by gFlyer View Post
Hi Steve,
Kind regards
gFlyer
Hello gFlyer,
While the Aera 660 can act as the navigator for a G5 based autopilot, it does not provide the A429 GPSS data needed to drive the analog outputs on the GAD 29B to provide this steering signal to old analog autopilots like the Century.
The minimum Garmin navigator for an installation like you describe would be a GPS 175 (or any of the GNS/GTN WAAS navigators).
Steve
Garmin G3X Support
g3xpert@garmin.com
Old Yesterday, 07:17 PM
Flybipe Flybipe is offline
Default Won't boot after new software...?
I finally got around to installing this new version of the software today. Once installed it now won't boot up and shuts down after the startup / spinning garmin logo screen. Is there a recovery mode or do I have to now send this somewhere?
Old Today, 08:00 AM
g3xpert's Avatar
Post
Hello Flybipe,
It would be best to contact us directly for assistance of this type. If you haven't tried updating from a USB connection, you should try that first.
Steve
Garmin G3X Support
g3xpert@garmin.com
