Old 01-12-2019, 06:11 AM
BCP Boys's Avatar
BCP Boys BCP Boys is offline
I have a similar setup. I think I understand your last post but a drawing would be better to understand what you are trying to do. On my system, I have a traditional dual Cessna switch that control 2 separate batteries, a separate switch that turns on and off my back up battery for the G3X system and an alternator switch. The backup battery switch is the first thing I turn on and the last thing that I turn off. It needs to be On to re-charge the backup battery (at least in my set up it does). The only thing I will emphasize is this, if I'm understanding you correctly you want the switch to be OFF and for it to still work as outlined above... It needs to be On for it work this way and also to charge the backup battery... otherwise, why would you even have a switch to the backup battery?
Amir
RV-7 QB - N174WM
Supporting VAF since the first visit
Old 01-12-2019, 07:02 AM
DanH's Avatar
DanH DanH is offline
What Charlie and Walt said. Two switches, physically separated or different. You want to be able to kill the master while bouncing around inside a cloud at night.
And label them "Master" and "Backup Battery" rather than the generic "Aux". You built it, so you don't need any labels at all. The whole point of labeling is to make it obvious to the next guy.
Dan Horton
RV-8 SS
Barrett IO-390
Old 01-12-2019, 08:22 AM
iamtheari iamtheari is offline
I stink at drawings. Maybe I stink at descriptions, too. The switch would have three positions. From bottom to top, they would be: OFF, which disconnects both the master and the backup battery. BACKUP, which connects only the backup battery. And MAIN, which connects both the backup battery and the main battery. It would not be possible to turn the backup battery off while the main battery is on. It would be possible to turn the main battery off while the backup battery is on.
But the point immediately below yours is quite valid: In turbulence, it would be quite easy to accidentally push the switch full down and shut off the entire airplane while trying to switch to backup power in the event of a main power bus failure. Separate switches are probably safer for that reason. In my plane, when all else is equal, safety makes the decision.
Old 01-12-2019, 10:58 AM
Mark33 Mark33 is offline
Like I'd mentioned in my previous post, check out the Honeywell 2TL1-31 switch. It's a very heavy duty double pole/three position switch with a lockout preventing you from inadvertently moving the switch into the off position, but it can easily be toggled between positions two and three. I'll defer to the rest of the experts with regards to your overall architecture of your switchology the do's and don'ts, but this Honeywell switch with the lockout might just do the trick and accomplish what you're trying to do.
Old 01-14-2019, 03:38 PM
Thanks for the part number suggestion. Switch part numbers are always fun to look through because there are a million different configurations. Honeywell's document about the TL series is no different.
Most likely I will simplify this to separate switches, but anywhere that I do use a 3-position switch, I now know that there are lockout switches available to use.
Old 01-14-2019, 03:41 PM
supik supik is offline
I think this is the switch Mark was referring to:
https://www.steinair.com/product/loc...h-dpdt-ononon/
Igor
RV-10 in progress
Build Log
Old 01-14-2019, 04:53 PM
Default Honeywell toggle switches
Yeah, that same Honeywell 2TL1- switch comes in about ten different configurations based on lockout position or no lockout at all, momentary or not, all three positions on, one position off, etc. etc. The last number that you put in after dash (2TL1-?) determines the configuration. Here's their pdf brochure of all their toggle switches and all of the different configurations that you can get them in. https://sensing.honeywell.com/honeyw...05430-3-en.pdf You just need study them a little bit to make sure you're getting the configuration that you want. There’s quite a few places online that you can order them from.
