Go Back   VAF Forums > Model Specific > RV-3
Old 01-10-2019, 06:56 AM
DanH's Avatar
DanH DanH is offline
Originally Posted by Toobuilder View Post
But if the -3 is like the -4 and Rocket and features the central keel, then you are going to have almost no room for your feet once you add the -8 gear towers. At least the -8 has the center of the floor free and its still intrusive.
So switch to one-piece gear, requiring outboard structure only.
Dan Horton
RV-8 SS
Barrett IO-390
Old 01-10-2019, 10:04 AM
Toobuilder's Avatar
Certainly an option. My neighbor had an RV-4 converted to a nosewheel and it featured a Grove style spring gear for the mains. Worked just fine.
Michael Robinson
______________
Harmon Rocket II -SDS EFI instalation in work
RV-8 - Flying
1940 Taylorcraft BL-65 -flying
Old 01-10-2019, 11:13 AM
randylervold's Avatar
randylervold randylervold is offline
moderator
Background: built/flew an RV-8 for 400 hours, then built/flew an RV-3B for 300 hours. Based on that experience I much prefer the RV-3/4 rod landing gear. Somehow it feels better, is more forgiving, and frankly I like the swept back looks as well.
The structure required in the fuselage for -8 style gear would be considerable and I can't imagine how it could be retrofitted with proper strength integrity without a boatload of heavy structure.
FWIW.
Randy Lervold
RV-12iS, empennage/tailcone, wings & fuse on order
RV-3B, first flight 2007 - sold
RV-8, first flight 2001 - sold
Old 01-10-2019, 12:31 PM
SHIPCHIEF SHIPCHIEF is offline
I agree with the 'Rod Gear' crowd. I built an RV-8, my wife has an RV-4. I fly them both.
I wish my RV-8 had the rod gear, the landing and ground handling are better, and I could "MAN SPREAD" in comfort on those long flights.. without those gear towers taking up leg room and generally being in the way when I work around the consoles and panel.
Scott Emery
http://gallery.eaa326.org/v/members/semery/
EAA 668340, chapter 326 & IAC chapter 67
RV-8 N89SE first flight 12/26/2013
Yak55M, and the wife has an RV-4
There is nothing-absolute nothing-half so much worth doing as simply messing around with Aeroplanes
(with apologies to Ratty)
2019
