Go Back   VAF Forums > Activity Specific > Aircraft Camping
Old 12-13-2018, 08:07 AM
It's been a while, but my wife & I used to do SNF & OSH in a -4, camping with 'big box store' gear. Queen air mattress, zip-together sleeping bags, 5-6 man tent (big enough for the queen mattress plus all our gear & tall enough to dress with some semblance of dignity), & a soft side cooler. IIRC, the tent weighs around 12 lbs & the mattress another 5 or so. Sleeping bags weren't particularly light,either. I'd put the tent & mattress in the 'tunnel' between my legs (extended up & toward the firewall) to keep CG reasonable. I don't remember all the numbers, but the 1st few trips were soon after I bought my 1st -4, and I was careful to stay within GW & CG limits, which are much more limiting than a -6. (I did have the advantage of a light weight wife.)
Funny thing about those $60 tents (I've had maybe three of them, over 20+ years) is that they seem to survive about as well as the $400 ones (and are a lot more comfortable). We went through some storms at OSH where the tent would lay over on top of us in the wind, and never had any damage or leaks. People around us with high$ gear would be ordering new high$ gear overnight because of failures in the storms.
Charlie
Old 12-13-2018, 08:11 AM
swjohnsey swjohnsey is offline
I use a Wisperlite stove. It will burn avgas but the lead really clogs it up fast. I usually carry the fuel bottle full of mogas or coleman fuel but will use avgas in a pinch.
Check out ebay for lightly used ultralite gear 'specially in the winter.
The little Coleman stove is bullet proof and cheap. I have one that is probably 30 years old in an aluminum container that doubles as two cooking pots.
Old 12-13-2018, 09:43 AM
N941WR's Avatar
N941WR N941WR is online now
Originally Posted by Pilotjkl View Post
I can totally agree with you about the pressurized canisters, Is this the model you recommended?
Thanks https://www.campmor.com/c/msr-whispe...lti-fuel-stove
That one works but I have seen people leave the hose behind or drop it in the sand.
This is my preference, if you can still find one:
https://www.amazon.com/Coleman-550B7.../dp/B0009VC7QK
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
Old 12-13-2018, 09:51 AM
N941WR's Avatar
Originally Posted by swjohnsey View Post
I use a Wisperlite stove. It will burn avgas but the lead really clogs it up fast. I usually carry the fuel bottle full of mogas or coleman fuel but will use avgas in a pinch....
Be very careful, if you ever use 100LL! Be sure to cover your food or you will be eating and drinking sone led.
Bill R.
SC86 - Easley, SC
Old 12-15-2018, 09:31 AM
Sky Designs's Avatar
Sky Designs Sky Designs is offline
Default Lightweight Tie-Down
As for your tie-down kit, we offer a nice ensemble of four aluminum chocks, a dozen aluminum spikes, and three nylon webbing "cinch straps" with S-hooks. Go to: https://www.skydesigns.aero/tie-down-chock-set for pricing and a photo.
The entire set weighs only 4.5 lb and allows you to:
Tie-down & anchor your airplane when you're camping on dirt/grass or...
Chock your airplane & tie-down at airports with lugs anchored into the ramp or...
Just chock your airplane when not tied down.
The 7075-T6 Aluminum spikes are 3/8" diameter and 12 inches long and can also be used for self-defense by you and up to five of your friends in case of a zombie apocalypse
A hammer is not included but if you’re traveling with an engineer, his/her forehead can be used to drive the spikes into the ground, otherwise a large rock will suffice.
[ed. Ken, welcome aboard! ;^). Folks....THAT is how you do a first post as an advertiser....reference zombie apocalypse! <g>. v/r,dr]
Ken Krueger - Aircraft Designer
Sky Designs Engineering
skydesigns.aero
Old 12-16-2018, 09:21 AM
Mike S Mike S is online now
Default Welcome to VAF
Ken, welcome aboard the good ship VAF
Old 12-16-2018, 10:10 AM
RV7ator RV7ator is offline
Default Stowage
We can carry a figurative ton in our 7 by keeping dense heavy things out of the baggage area. I made brackets that are secured by the spare carry-through cover screws under your knees, either side of the fuel selector box. These have slots for lashing down goodies like tie down stakes, guns, ammo, water jugs (filled when crossing desert/remote) anything short and heavy, or even long, across the face of the selector box (provided you don't have a big FI pump housing). If you don't have the 6's battery box aft of the firewall, long things can be secured between the peddles and fuel selector. Make anchor points that are held by the center cover retention screws. It's all quite comfortable, your legs extend over the load top.
Having the heavy stuff forward doesn't so much bias the c.g. forward as it helps not biasing the load c.g. aft on the longer baggage area arm.
John Siebold
