Hi i need to make a soft reset but i forget the way to please help
H HSANTIBANEZ Well Known Member Apr 9, 2015 #1 Hi i need to make a soft reset but i forget the way to please help
g3xpert Well Known Member Advertiser Apr 9, 2015 #2 HSANTIBANEZ said: Hi i need to make a soft reset but i forget the way to please help Click to expand... Hello, For a GDU 37X display, push/hold bottom left softkey and bottom right softkey, then press on the top of the range rocker switch. Steve
MarkW Well Known Member Friend Apr 10, 2015 #4 While on the topic. Isn't there a procedure to enter setup without powering down?
g3xpert Well Known Member Advertiser Apr 10, 2015 #5 MarkW said: While on the topic. Isn't there a procedure to enter setup without powering down? Click to expand... Hello Mark, You bet. Just perform the 3 key reset then hold down the bottom left softkey to enter config mode on a GDU 37X. You can go in/out of config mode all day without ever cycling power. Steve
