Tell me a few things:
HOW MUCH does the database update for the
696 cost per year?
Does 696 have GEO-Referenced Approach Plates and airport maps?
Does 696 show TFRs if it has had a data update before getting in the airplane?
Can the 696 be used for getting preflight weather before flying?
Can the 696 file an IFR flight plan before the flight?
Can the 696 recommend an IFR route for the flight between two airports?
Can the 696 be used to check VAF forum while traveling?
Can the 696 keep you in touch with the office by email while traveling?
Can the 696 allow you to find a good restaurant near where you are staying?
Can the 696 all you to read PDF copies of your aircraft equipment manuals while traveling?
I can go on but the
696 is more than twice the price for the hardware. The iPad is being used by Airlines as replacement for PAPER in the cockpit. That is all I want it for but I get more out of it than just an EFB.
Garmin and Jeppsen both have excellent products but they both have one other thing in common. They both cost too much money. There are other products that are available in some cases that are just as good for a LOT less money.
