Partially built Empennage and Wing kit Questions
Kapunui
I'm New Here
Hi all, I finally am getting close to the point of starting on my very own rv8. After lurking for a while I am pulling the trigger and starting my dream project. That being said I found a partially built wing and empennage kit and am wondering what I should be looking for in particular. Attached are pictures that I was set already. The wings are from 96 or 97 and I am also worried that I may have some issues with compatibility with a new fuselage kit. Any advice would be much appreciated.
PHP:
[IMG]https://photos.google.com/u/1/search/_tra_/photo/AF1QipNMHp9aNt7RMDfDOxW3OxdxH8UjcYmab0oP_8Yr[/IMG]
https://photos.google.com/u/1/search/_tra_/photo/AF1QipPKptj3AYC9Wd1Dpp6ncDlIEFiZdxxWSbklRT_m
https://photos.google.com/u/1/search/_tra_/photo/AF1QipNf-tvW2kkunDV970acc7hmfnbCFmEcMOfcgz7T
https://photos.google.com/u/1/search/_tra_/photo/AF1QipNWO4gb-P6NAEdomfSarm6W6xiFwKMg8Knx9eo5
https://photos.google.com/u/1/search/_tra_/photo/AF1QipOZz84jLvGmAz5gYIRd_SBB5np_lKhfPaT-pHeE
AF1QipOjjbvOfiXjQDjOuZlNrMVeaAdseu0l5hfd-vvQ
https://photos.google.com/u/1/search/_tra_/photo/AF1QipMNJ5rwT_kaeqTr4TjXp5Wyi0T6JHRW1VRtY22v
Colorado Springs
Hi Ryan,
I see you are in Colorado Springs. There are many builders/flyers in this area and Denver that will gladly offer knowledge and help.
I suggest you contact Van's on the compatibility questions.
Hi,
Did you ever get your answer?
I'd be interested in what you found out because I have the same situation.
I have the older wings but was told by Vans that they would fit the new center section.
Russ
