5 year hose replacment
edward7048
Does the 5 year hose replacement start at the year of manufacture
or the year the engine was put into service? What hose are to be
replaced?
I just replaced a rubber (Aeroquip 303) hose to the oil cooler that was 14 years old. The rubber had gotten harder than new hose but it was in good condition and probably would have lasted a lot longer. There is no particular limit on an Experimental. 5 years seems a little conservative to me.
There is a 5 year hose replacement requirement for SLSA.
For ELSA it is a recommendation.
Rotax recommends 5 year replacement on their engines.
John,
I agree, but it's tough to assess a hose under fire wrap. I bought the Teflon fuel hose package from Aircraft Specialtyand will install it at next annual in March. I am dreading the oil and coolant hose replacement in 2017. I think I'll look for a premium automotive heater hose for the coolant lines. I think the lines are 5/8" except for the radiator hoses. The spring in the radiator hose to prevent collapse seems overkill. I would like to hear some operating experience on that. I have seen some coolant hoses in automotive applications that are extremely flexible and do not kink.
Rich
I'm a big believer in the 5 year hose change because you can't pull over to the curb, you don't have X-Ray vision to look under fire sleeve every annual, you can't see the interior of the hose where the clamp is to see the liner of the hose cut, you can't tell if the clamp was applied to tight, you can't tell if a hose is good or bad by squeezing as some think. If the hose is hard you're way past replacement time. You can't see Ozone that damages hose and hours on a hose isn't the only thing that causes damage. I have seen countless hoses that were damaged that the owner or a mechanic thought and swore were good, not to mention the off field landings caused by a bad hose.
Gates did a hose report years ago and found at 3 years you had a few failures, but starting at 4 years the hose incident rate shot up and the more years that it went on the worse it got.
Rotax changed the replacement on the red Teflon hose that feeds the carbs to on condition.
Here is a kicker. The FAA legal ruled a few years back that Rotax or an aircraft company can not put any rules in place more restrictive or on the other hand give away the farm over what the FAA already has in place.
I'm a big believer in the hose change, but legally Rotax can not make it legally binding. This particular rule has been discussed on several forums.
The RV12 is a fairly easy plane to do the hose change on. One person should be able to do the entire Rotax hose change with all its components in a day on an RV12. The fire sleeve can be re-used.
Generally speaking;
Many people seem to use the Gates Barricade hose because of its top rating for ethanol and low vapor seepage. You don't need the high pressure fuel injection hose, but can use the carburetor rated hose. It has a tad more stretch and goes over fittings easier with less chance of shearing off the inner liner and causing debris. The top coolant hose and the two bottom side hoses on each side are 17MM and there is no US equivalent and it is made by only one company for Rotax. The other large coolant hose is 25mm or 1" and many seem to use either Dayco or Gates Green Stripe hose. There is also a Rotax coolant hose that has a 90 degree bend.
The biggest issues is to get people to use proper hose clamps and not to apply too much clamp pressure. Don't use garden hose style clamps on fuel line. The next thing is not causing hose debris which comes from the wrong type hose cutter, forcing hose over a fitting, wrong type clamps, too much clamp pressure and failing to blow the hose out before you put it on the fitting. Pushing hose through fire sleeve can get debris in the hose so it needs to be blown out. Don't forget the rubber carb sockets, the carb diaphragms, the 66mm carb balance tube rubber hose. Some people do use springs in some hoses to keep the radius fully open on tight bends. This would depend on the aircraft MFG and engine installation. When a hose gets a reduced radius it slows the flow of oil or coolant and causes high temps.
p.s.
Hose debris isn't caused by the hose unless it was a bad batch from the MFG. which is rare it is caused by poor installation procedures.
The reason we use Teflon hose is because the liner is impervious to most all chemicals in fuels, oils, hydraulic fluids, etc. I personally dont know all the chemical makeup of the fuels that you guys use. We do know (from another aircraft manufacturer) that 'some' hoses they were using would begin to fail after a period of time with mo gas. Time frame started about 3 years. I dont know the flight hours. BUT---dark deposits of the liner were getting into the carbs, creating a 'mess'. Inspecting the hoses found the there were crack, and small pieces of the liner missing. (Think of a mud puddle after it drys and begins to crack and shrink.)
Teflon eliminates this issue. Rotax is using Stratoflex 101 hose for the carb hoses OE on the 912 engines. The other fuel hoses were supplied by the airframe manufacturers. Aircraft Specialty and TS Flightlines spent alot of time working on a replacement package that was reliable, and did not have to undergo the 5 year replacement recommendation. Yes its is more expensive and more involved then your gas hose from auto parts store with hose clamps, but after seeing some of the hose failures that we saw, teflon was our choice.
Tom
RV-12 Prebuy Question
I?m looking at purchasing a 2014 SLSA. It just completed annual. I asked about the 5 year rubber hose replacement ?requirement?. I was told the hoses were in excellent shape, aircraft quality, and it would be ?pointless? to replace them.
I?m new to RVs, and would appreciate any feedback. Thanks
Rotax may not "require" a 5 year replacement. However the SLSA manufacturer "can" "require" the 5 year replacement based on Rotax's recommendation.
Read above and verify if it is correct... if it is a S-LSA, the 5 year hose requirement is mandatory. Not mandatory for E-LSA.
The way the ASTM's that regulate SLSA aircraft are written, the manufacturer is responsible for regulating what maint. and inspection details must be done for continued airworthiness (the annual condition inspection sign off says the inspection was done "in accordance with the manufacturers inspection procedures)
The engine is approved under a different ASTM than the airframe is so the engine manufacturer has the authority to specify specifics regarding the maint. and inspection of the engine.
Rotax stipulates that all rubber components have a mandatory replacement every 5 years. That means in the FAA's eyes any SLSA must comply with that requirement to remain airworthy.
This requirement does not apply to any RV-12 that is not certified as an SLSA.
Maybe if enough of the SLSA owners request LOA's from Vans for the Aircraft Specialty teflon hose kit they would grant the approval making the sourcing and fabricating of the hoses much easier.
As already mentioned, Rotax owns the management control of components that are part of their engine that they certified under the engine ASTM's.
Van's only controls the parts that are specific to the installation on the airframe (oil cooler hoses, for example).
So Van's can not approve the use of different parts that are engine specific (such as fuel system hoses related to the carburetors, etc.).
The 912ULS
Carb hoses for the RV12s come from Rotax on the engines. Similar manufacturers using that engine buy them that way too. Some dont, and the airframe manufacturer ( and even some builders) create their own fuel systems. The Vans designed system is much superior to alot of them out there---some of the pics would scare you.
But, we do supply the other hoses that Vans specs, like the fuel supply and oil cooler. And yes we do have the carb hoses for the 912ULS. (Rotax seemed to like it).
Tom
Tom and I are always willing to work with any OEM that wants to offer an improved product to their customers. We would be happy to work with Vans in order to offer SLSA customers the same hoses we have been utilizing on EAB and ELSA builds for years.
Scott,
I think that there is a great opportunity to work together here to help our mutual customers and fellow aircraft owners. We have already been supplying complete conductive Teflon fuel and oil systems for EAB and ELSA RV12 owners for years. We could break out the "Airframe specific" hoses (All 3 oil lines and the "NON Engine Specific" fuel lines) and offer them through Vans to your SLSA owners. The "Engine Specific" hoses could be provided through Rotax. At that point, SLSA owners would have an easily sourced complete Fuel and Oil line package made of conductive Teflon that would no longer be subject to the 5 year replacement intervals.
One additional benefit to the oil lines is that we now have an option for an integrated Stainless banjo oil line fitting which greatly increases the oil line clearance from the exhaust on the oil return line.
Send me a PM if you are interested in discussing further.
Steve
