I installed the motor in my RV12 and am now attaching the cowling. I found that the prop shaft and cowling are 3/8" off center. I checked, and rechecked my trimming of the cowling and it is exact. After much wailing and mashing of teeth, I measured the motor and found it to be off center. The front end is pointing to the left about 3/8". After pondering, with the aid of several beers, I remembered that the upper portion of the front landing gear did not mate flush with the firewall. When the bottom plate was attached to the bottom of the fuselage, the top section touched the firewall on the left side but was raised about 3/16" from the firewall on the right side. . . . I do remember setting it on the flat edge of the work bench and confirmed it was slightly off square. That was several months ago. I went ahead and installed the engine and tightened everything up and the gap disappeared. Now looking at it I see the firewall at that point is bowed out.
My guess is that the front landing gear was manufactured slightly off which is the cause of the problem.
My questions to the wise people on the forum: Has this happened to anyone else? Do I have to remove the engine to replace the front landing gear? Did I screw up the alignment forever by possibly bending the firewall when I tightened the motor mount bolts? Should I sell the plane and take up gardening?
