Hi All,
There doesn't seem to be a thead about this topic. Do I need to purge the system when I clean the oil tank? The o rings for the valve covers are fairly expensive from the supplier in NZ. I have also had advice that if the tank need ed to be cleaned the lead would be obvious on the drain plug when it was removed. I have about 370 hours now and I guess I am using 100LL about 30% of the time.
Cheers
Julian 120316
Cheers
Julian 120316
