Old 11-03-2018, 07:08 PM
1949MGTC 1949MGTC is offline
Default Anyone install Notification 18-04-06 Alternate Regulator and Cooling
I know many people have installed the Hektik regulator but has anyone installed the NACA scoop per notification 18-04-06? Iím interested in how well that scoop installation went on the cowl. Any comments?
https://www.vansaircraft.com/pdf/Not...2018-04-06.pdf
Thanks in advance
Old 11-04-2018, 05:22 AM
benfra benfra is offline
Default Vans Hektik Kit
I recently installed the kit, works well. Install as directed ,no problem. The edges need trimming on the tiny lines, the lenth was perfect, my cable barely touches the duct so I didn't trim. Use Flox and rough up both surfaces before attaching. I did use new electrical connectors to the unit. Works Great!!! Keep the cowl to NACA scoop edges sharp, except for the small front intake. Ben N40BF RV 12 RV 7A . I will suggest installing the regulator first so you can locate the duct properly.
