Old 03-08-2018, 10:35 AM
Aircraft Specialty Aircraft Specialty is offline
I just wanted to give an update that due to the popularity of the rigid tube packages, we have taken steps to streamline our production. We now aim to keep several sets built and in stock. In the event we do run out, we are able to now build these on a 3 business day lead time. Wing rigid tubes are the same. The flex lines retain their standard 3-5 business day lead times. (More to come on all this including some new videos of a major shop upgrade we just completed related to rigid tube development.)
The current website message of reduced availability until 3-20 is NOT applicable to any of the RV-14 hoses and tubes.
Happy Building!
Steve
Steve Tschurwald- Aircraft Specialty LLC (Your source for Custom Parts for Experimental Aircraft), AS FLIGHTLINES (Joint Venture with TS Flightlines)
aircraftspecialty@gmail.com
www.aircraftspecialty.com
www.asflightlines.com
Old 07-14-2018, 05:08 PM
I just wanted to give an update to all our RV-14 Customers. We are currently on Revision 7 of the installation manual for our cabin fuel and brake line package. We have a lot of these being installed at the moment. We always appreciate and welcome customer feedback, and the additional pictures and data you provide allows us to update our installation manuals to make it even easier for future builders.
This revision adds some information on the parking brake installation, as well as some additional pictures for different parking brake actuator cable routings and part numbers that customers have been utilizing for the cable actuator assembly.
http://www.aircraftspecialty.com/PDF...l%20Manual.pdf
We also updated our Firewall forward hose package install manual to Rev 3 dated 7-14-18. We have added several additional hose configurations to include a backup pad mounted B and C alternator for the RV-14A and an upright B and C oil filter for the RV-14A.
Here is a link to the updated manual
http://www.aircraftspecialty.com/PDF...RV-14%20FF.pdf
Please clear out your browser cache or the new options/updated PDF files may not show as available on our website.
http://aircraftspecialty.com/rvproducts.html
We also updated our rigid tube video section of the website. For those of you who purchased our RV-14 cabin fuel package, the 11:30 mark of the Rigid tube video shows how those tubes are now being fabricated.
http://aircraftspecialty.com/howwemake.html
Thanks again to all the builders that have contacted us requesting custom hoses for different configurations on their aircraft. This has helped us to create a massive database which is growly daily of many different hose configurations that are custom to the plane and options that YOU want.
Steve and Tom
Old 07-26-2018, 04:46 PM
jdmrv7a jdmrv7a is offline
Default Perfect fit RV14-A
Steve,
I just installed the fuel lines I purchased from you on my RV14-A, perfect fit. I spent 3 hours completing all of Section 31 (Fuel System). The fuel line brackets from Van's took half of that time. Your pre-bent lines fit perfect. I am not sure how much time you saved me but I know those fuel line bends are complex on those short tubes. Your machines for bending those tubes are setup perfect. You and other parts suppliers have made my quick build experience enjoyable! Thanks
RV14-A QB
Factory Lycoming IO390 X, HZ CS 2 Blade,
Garmin Dual G3X 460, GTN 625, A/P 507,
GTR 200 & 20 COMM's, 245 audio, GTX 45R
Repairman Certificate
Old 07-26-2018, 05:00 PM
Originally Posted by jdmrv7a View Post
Steve,
I am glad that you liked the installation. We have really enjoyed working on rigid tube development for several of the RV models.
I see that this is your first post on VAF. Welcome!!! And thank you for your comments. It's posts like this that make us really enjoy what we do. We love innovating new things and helping builders in a small way toward their first flights.
Thanks again and we hope to once again earn your business when you are ready for your firewall forward hoses.
Take care,
Steve
Old 10-21-2018, 11:44 AM
We have now updated the website to include a few more Rigid tube options for the RV-14. These include the wing vent lines which are set up for either the stock installation, or the JDAir Vents. We also have the sniffle valves that are located firewall forward and those come both pre-bent and also beaded with a Milspec beading tool.
Happy building and thank you to everyone who has helped us develop these new products by doing fit tests for us and providing product feedback.
Old 10-21-2018, 12:33 PM
JoeRV14 JoeRV14 is offline
Default Excellent quality
Steve,
Thanks for all your help! Iím extremely satisfied with my RV14 brake and fuel lines. You and your products are truely an asset to the RV community!
Joe Hesano
Old 10-21-2018, 12:38 PM
snopercod's Avatar
Originally Posted by czechsix View Post
...rationale for using fittings as a passthrough ...
I'm with you. I used bulkhead fittings to pass all lines through the firewall on my Lancair, and I'm really sorry I did it that way. Same with the hydraulic lines to my gear. The installation looks nice but the problem is tightening the B-nuts on either side - and you WILL have to tighten them after your first 20 hours. To keep the entire bulkhead fitting from rotating, you have to put a backup wrench on the nut holding the bulkhead fitting to the firewall. Not only does that job require two people, but the sound insulation on the inside of my firewall covers part of the bulkhead fitting and has to be dug out to gain access for the backup wrench. I really didn't think through my decision when I decided to do it that way. My brake lines, however, are one piece (Nyla-Seal) from master cylinders to the brakes so there are no intermediate fittings that need tightening. Live and learn...
(2019 dues paid)
Old 11-19-2018, 09:24 PM
To add to our growing list of configurations for the RV14/14A, we now have the Beringer gear leg hose kits available for both the Nosewheel and Tailwheel aircraft.
We are currently working through a variety of different cabin line configurations with several beta testers. This will help us to finalize locations for PB and ALIR valves to "Standardize" the install for those who are looking for a complete "drop in" package.
On that note, we also have worked out a specific package with Beringer that is for AS Flightlines customers (Aircraft Specialty and TS Flightlines). This package allows us to sell all the Beringer components direct to our customers without any of the "do it yourself" Beringer hoses and fittings. Those are all credited out and then we can substitute our pre built and pressure tested assemblies.
If you would like to utilize our lines, Tom or I are able to sell you ALL the Beringer components you will need as well as all the hoses pre built.
We will release more information in the coming months as we continue to finalize various configurations of these packages.
Steve
Old 04-05-2019, 11:16 AM
A few more updates on available RV14 configurations.
1. We have now finalized the 14/14A Beringer cabin configurations for Parking Brake Valve, Parking Brake/Anti Skid Valve, and standard configuration without either parking brake or anti skid valve.
Shown below is the 14 Tailwheel with Beringer Parking Brake and Anti Skid valve configuration.
2. You may also notice something different about the valve configuration in this picture. It is the Andair Type 7 valve with the off configuration in the aft position. We are working on the release of a drop in package for those who want to go with the alternate valve. This package will include all tubes to completely plumb the cabin fuel system for the RV14 and will also include a drill template to mount the alternate valve correctly. This will be necessary to ensure that the tubes are a perfect fit. This package will be scheduled for release in the next several months.
3. Finally, we are back at work on the Duplex valve configuration for the RV14 due to growing interest in that configuration from customers. We have plumbed a few rv14 aircraft in this configuration so far, and have realized that the location of the valve is absolutely critical for the 4 rigid tubes to fit correctly. In addition, the duplex valve requires a new mounting bracket which we are now CNC machining and bending, new clips to hold the tubes as well as some cover plate and other tunnel modifications. Due to the complexity of doing this correctly, we are working with 2 beta testers to ensure that we can provide a complete drop in package for the duplex valve. This package will provide ALL the tubes and modified components to make installation easy. This is a work in progress, and will take several months to complete and finalize.
We look forward to continuing progress on these projects and continuing to innovate new products based on feedback from the Vans community.
Thanks again for letting us be a part of your projects.
Steve and Tom
Old 06-06-2019, 11:04 PM
First off, I want to sent a thank you to beta Testers Mike and Patrick. Mike helped us design and test fit the Type 7 Valve cabin fuel kit that we are releasing, and Patrick has been working with us very closely to make our Duplex valve installation a COMPLETE drop in package. That one isn't complete yet, but we are making good progress.
Today, we are ready to announce the immediate availability of a slightly different version of our RV14 cabin fuel line package. The Andair Type 7 valve is different than the stock valve in that it has "Left", "Right" and "Off" in a more traditional Forward/Back configuration than the stock valve that comes with the RV14 kit. Making this valve fit in the -14 posed some unique challenges. The clearances are extremely tight when compared to the standard setup. Also, the valve requires different mounting holes to be drilled. We set out to design this as a drop in configuration. This necessitated machining a drill template so that the new valve could easily be located perfectly accurately, which would then ensure that the tubes fit.
This kit includes a drill template, 3 rigid tubes, and one flex hose assembly. It completes your entire cabin fuel system for those who would like to utilize the Type 7 Andair valve. The pricing on this complete kit (without the valve) is $299.95.
Also, we have been making progress on the duplex valve installation for the RV14. The challenges on that one are numerous as we want to ensure that the kit and all components fit perfect without customer modifications.
We currently have the following items of that kit complete. 1. Upper and lower tubes 2. Spar clips for the tubes 3. Valve mounting plate 4. New Doubler plate. Items outstanding are the new tunnel cover that is required. Also, we are working on the section of the tunnel forward of the valve to accommodate either an SDS or EFII system.
Our RV14 Cabin brake and fuel line package install manual has been updated to show the type 7 valve installation, a preview of the duplex installation, and Beringer Cabin and Gear leg hose packages.
Those can be found for download on the product pages as a pdf link.
http://aircraftspecialty.com/rv-14.html
Also, if anyone is interested in how the tubes or other products are fabricated, we have several videos detailing the process.
Happy building!!!!!
Steve
