BruceMe
So by far the best method I've ever done is messy but works great. You use an old oil fashioned oil can pump with positive pressure the fluid from each wheel up through its master and fill the reservoir.
I'm working in my buddies auto shop and all he had was the newer vacuum style. I imagine it's similar principled but from the top pulling up and in. I couldn't figure out where to put the vacuum.
What is the best (no bubbles) cleanest (no messy spills and drenched wrenching) method anyone here knows for bleeding aircraft brakes?
Thanks!
Thanks!
